35PSI - Means What
Goto page 1, 2  Next
equeen
PostPosted: Sat Sep 29, 2012 7:01 am    Post subject: 35PSI - Means What Reply to specific post Reply with quote
Okay, I know the bowels of the engine need attention and there's risk in it not getting proper attention now.
However,simple question regarding cold oil pressure at 35psi then dropping within 30 minutes of running to 5-10psi.
Are all the appropriate engine parts getting adequate lubrication when the pressure is at 35PSI?
If above answer be yes; then operating the tractor for 15-20 minutes with psi in the range of 20-35 causes no additional harm to engine? (About 20 minutes at the time is all I need of tractor time in the garden most of the time.)
R Geiger
PostPosted: Sat Sep 29, 2012 7:03 am    Post subject: Re: 35PSI - Means What Reply to specific post Reply with quote
equeen wrote:
(quoted from post at 00:01:38 09/30/12) Okay, I know the bowels of the engine need attention and there's risk in it not getting proper attention now.
Your oil pressure is completely normal, run it!
old
PostPosted: Sat Sep 29, 2012 8:37 am    Post subject: Re: 35PSI - Means What Reply to specific post Reply with quote
Those numbers are what 95% of those old tractors ran at. If you want higher numbers switch to a straight weight oil or a heavier oil
Dell (WA)
PostPosted: Sat Sep 29, 2012 8:38 am    Post subject: Re: 35PSI - Means What Reply to specific post Reply with quote
equeen........congratulations you have just found the effects of VISCOSITY. Cold oil is thicker than HOT oil. Even water has a viscosity factor; cold is ICE and HOT is steam. Isn't that amazing. You need to be concerned about HOT oil pressure; it is what keeps the bearings from rubbing on the crankshaft journals. It should be intuitively obvious that metal to metal rubbing can be "expensive". The N-Oil is pressure relived to 35psi max when cold. Oil pressure is a combination of oil weight and oil pump efficiency. .........oily Dell
R Geiger
PostPosted: Sat Sep 29, 2012 9:09 am    Post subject: Re: 35PSI - Means What Reply to specific post Reply with quote
The main thing that determines oil pressure is the clearance in the bearings. Too much clearance and I don't care what oil you use there will be no pressure. Granted you need a good pump to start with but the best pump in the world will not create pressure without the resistrictions from the bearing clearance.
NOXJohn
PostPosted: Sat Sep 29, 2012 9:22 am    Post subject: Re: 35PSI - Means What Reply to specific post Reply with quote
I ran a 1949 8N with 5 pounds of oil pressure when hot for 20+ years and worked it hard. I bush hogged and plowed and mowed grass for hours. When I finally tore it down and rebuilt the engine It showed no undo wear. These low rpm machine will run a long time as long as the bears etc. get some oil even if it is just a little. Just change the oil around every 50 hours of operation and it will be good for a long time.
Mad Farmer
PostPosted: Sat Sep 29, 2012 9:47 am    Post subject: Re: 35PSI - Means What Reply to specific post Reply with quote
My 9N runs just like that with 20/50 W in summer.
Been that way since I've owned it, 1989.
It don't make knocks or taps either.
TheOldHokie
PostPosted: Sat Sep 29, 2012 9:55 am    Post subject: Re: 35PSI - Means What Reply to specific post Reply with quote
R Geiger wrote:
(quoted from post at 13:09:43 09/29/12)
Precisely. And I don't care if you have 80 PSI pump oil pressure that oil pressure won't keep the journals clear of the bearings if the clearances are too wide. The journal is held off the bearing surface by a localized pressure differential inside the bearing shell that is orders of magnitude greater than pump oil pressure - well up into the thousands of pounds. That differential comes from the formation of a hydro-dynamic "wedge" of very high pressure oil (red area in the drawing) opposite the load on the crankshaft. It is produced by the journal surface dragging oil around the bearings as it rotates and compressing it in the constricted clearance opposite the load. Too much bearing clearance and that wedge won't form and the journal is forced down onto the bearing surface by the load. It is this hydro-dynamic phenomenon that allows a splash lubed lawn mower engine to maintain a bearing oil film with ZERO pump oil pressure. The three factors that affect the formation of that wedge are:
  • Bearing clearance
  • Oil viscosity
  • Surface speed of the journal
Pump oil pressure has virtually nothing to do with it.
TOH
souNdguy
PostPosted: Sat Sep 29, 2012 10:50 am    Post subject: Re: 35PSI - Means What Reply to specific post Reply with quote
35 cold and 10 hot is still acceptable..
soundguy
equeen
PostPosted: Sat Sep 29, 2012 12:01 pm    Post subject: Re: 35PSI - Means What Reply to specific post Reply with quote
Okay, another question or two.
Seems that the tube from the oil guage runs to a plug near the rear of the engine block.
I'm guessing that the the "plug/fitting" simply opens up inside the oil chamber/cavity in the engine block thus registering the oil pressure as it exists in the oil pan, oil cavity in engine block, oil cavity in head, oil cavity in oil filter container???
In other words the oil pressure as it exists in the oil, against any metal surfaces, air spaces, whatever in the oil cavities wherever located inside or outside - but part of engine oil cavities????
TheOldHokie
PostPosted: Sat Sep 29, 2012 12:20 pm    Post subject: Re: 35PSI - Means What Reply to specific post Reply with quote
equeen wrote:
(quoted from post at 16:01:01 09/29/12) Okay, another question or two.
The fittimg is installed in the main oil gallery that runs front to rear alongside the camshaft. The pressure shown is what is being delivered to the main and rod bearings.
TOH
Dell (WA)
PostPosted: Sat Sep 29, 2012 12:51 pm    Post subject: Re: 35PSI - Means What Reply to specific post Reply with quote
equeen........you have the oil flow BASSACKWARDS......oil flows from the oil pump, which is part of the #1 crankshaft bearing at the front of the engine, thru the camshaft gallys and out the BRASS "T" at the back of the engine where one side of the oil flow dead ends into the dashboard oil pressure gauge. The OTHER leg of the brass "T" returns the oil flow THRU the oil filter on the left side of the engine OUT thru the BOTTOM of the oil filter canister around to the governor CUP where it leaks INSIDE the front of the engine camshaft cover plate. Yer I&T FO-4 has a great pictorial of engine oil flow. (buy-1, $25, cheap) ........respectfully, oily Dell
equeen
PostPosted: Sat Sep 29, 2012 3:13 pm    Post subject: Re: 35PSI - Means What Reply to specific post Reply with quote
Too many manuals, too little time, too lazy to look. However, Fig. F027 appears to be the Oil circuit diagram of which you write.
Your writing was better than the picture.
And, yes, I stay bassackwards lots of the time.
Thanks for your very helpful response.
55deere70
PostPosted: Sat Sep 29, 2012 4:06 pm    Post subject: Re: 35PSI - Means What Reply to specific post Reply with quote
How MUCH oil pressure you have is not nearly as important as the fact that you HAVE oil pressure.
leej
PostPosted: Sat Sep 29, 2012 5:24 pm    Post subject: Re: 35PSI - Means What Reply to specific post Reply with quote
55deere70 wrote:
(quoted from post at 01:06:13 09/30/12) How MUCH oil pressure you have is not nearly as important as the fact that you HAVE oil pressure.
"I'm guessing that the the "plug/fitting" simply opens up inside the oil chamber/cavity in the engine block thus registering the oil pressure as it exists in the oil pan, oil cavity in engine block, oil cavity in head, oil cavity in oil filter container???"
Yes, queen, your engine will either seize or blow up if oil pan or crankcase pressure drops much below 10 PSIG. Much more than 10 will probably blow the oil filler cap off. It is truly a fine line here that we walk. Serious business. You should probably pull the engine immediately, without further delay or useless testing & eyeball the internal/deepest guts to see for yourself, just what may be amiss. You shouldn't even wait until sunrise.....no telling what could happen overnight!
Goto page 1, 2  Next
Page 1 of 2
