Briggs 16hp vanguard v-twin starter
mightymolinekid
PostPosted: Sat Sep 29, 2012 11:50 am    Post subject: Briggs 16hp vanguard v-twin starter Reply to specific post Reply with quote
Hey all, I have a Bolens 1669 with a 16hp Briggs and Stratton Vanguard v-twin. The junk plastic starter drive gear went, as I'm sure is common with these. Is there some national secret to getting the top starter bolt out? I'm guessing it takes some kind of special tool...is there an upgrade to the plastic gear or is it designed to be the sacrificial part, instead of the flywheel ring gear. Any help appreciated!
joe csuti
PostPosted: Sat Sep 29, 2012 3:51 pm    Post subject: Re: Briggs 16hp vanguard v-twin starter Reply to specific post Reply with quote
Briggs sells a special universal socket pn 19353 for starter removal but same pricey,try useing a 13mm 12pt 1/4" drive socket & a univ joint,if too big to fit in try a 1/4" wobble extention.Briggs used two different drive assemblies with nylon gears on vanguard eng,both are designed to be used on flywheel with an aluminum ring gear,do not use a drive with a steel gear,these are designed for a flywheel with a steel ring gear.
t.r.k.
PostPosted: Sun Sep 30, 2012 11:17 am    Post subject: Re: Briggs 16hp vanguard v-twin starter Reply to specific post Reply with quote
Just want to add that the metal gear has 1 less tooth than the plastic gear does.
If your starter is having trouble pushing the engine over compression, The engine probably needs a valve adjustment.
A lot of those starter bolts have a Torx socket in the head. I usually can get them with a 1/2" 1/4 drive socket,it goes by the flat in the starter drive onto the bolt at an angle, but usually works.
CAROGATOR
PostPosted: Sun Sep 30, 2012 4:35 pm    Post subject: Re: Briggs 16hp vanguard v-twin starter Reply to specific post Reply with quote
Definitely try valve adjustment first!! You also have to KNOW the proper procedure as it does not set on TDC. Piston has to drop 1/4" past TDC. It has to set on compression relief cam.
d beatty
PostPosted: Mon Oct 01, 2012 9:05 am    Post subject: Re: Briggs 16hp vanguard v-twin starter Reply to specific post Reply with quote
Have you ever thought of looking on Ebay there are a lot of Briggs and stratton starters on there. If you buy a new one they start out around $ 80.00 on up.
mightymolinekid
PostPosted: Mon Oct 01, 2012 9:11 am    Post subject: Re: Briggs 16hp vanguard v-twin starter Reply to specific post Reply with quote
Thanks for the help everyone! Can just the gear be replaced??
chuck in IN.
PostPosted: Mon Oct 01, 2012 4:17 pm    Post subject: Re: Briggs 16hp vanguard v-twin starter Reply to specific post Reply with quote
Yes you can replace just the gear.I sell them for $3 each plus shipping they list for around $6 at most shops
CAROGATOR
PostPosted: Mon Oct 01, 2012 4:38 pm    Post subject: Re: Briggs 16hp vanguard v-twin starter Reply to specific post Reply with quote
Sorry! Wrong Thread.
Stephane lacasse
PostPosted: Sun Jan 27, 2013 6:48 am    Post subject: Re: Briggs 16hp vanguard v-twin starter Reply to specific post Reply with quote
do you still have the 16hp Briggs and stratton vtwin starter plastic gear for sale?
