| Author |
Message |
2-lunger Guest
Posted: Sat Sep 29, 2012 1:09 pm Post subject: rd 450 flywheel for a 560 |
im currently installing a rd 450 in a 560 and would like to know what others are doing with the flywheel .I dont need a $2500 slipper clutch due to 15.5x38 tires and 5000 and 6000lb weight class's. I am thinking of machining the hub off of the back of the stock deisel flywheel and redrilling it for the rd bolt pattern then making a spacer to go between the flywheel and crank .Am I on the right track or am i building a bomb that will cut the tractor in half the first time I turn it up to 4000 rpm.
Thanks Lee |
| Back to top |
Ole Johnny Regular
Posted: Sat Sep 29, 2012 1:30 pm Post subject: Re: rd 450 flywheel for a 560 |
All I know is let me know BEFORE you wind that thing up so I can be in the next state. |
| Back to top |
Bouncer Tractor Guru
Posted: Sat Sep 29, 2012 1:52 pm Post subject: Re: rd 450 flywheel for a 560 |
If you are going to turn it loose at 4 grand, you better make for sure you have a real good clutch, SFI approved flywheel, and a blanket. |
| Back to top |
2-lunger Guest
Posted: Sat Sep 29, 2012 4:01 pm Post subject: Re: rd 450 flywheel for a 560 |
does anyone know of somebody that makes steel flywheels for single disk clutch. I know custom tractor parts makes dual disk set ups but I would like to go with a single if I could. Thanks Lee |
| Back to top |
Posted: Sat Sep 29, 2012 5:21 pm Post subject: Re: rd 450 flywheel for a 560 |
South Bend Clutch will make you anything you want.
SBC
| Back to top |
AFTERSHOCK Regular
Posted: Sat Sep 29, 2012 6:07 pm Post subject: Re: rd 450 flywheel for a 560 |
Mike @ H&H Farm Repair. I'll see if i can dig his number up for you. Good flywheel setup. |
| Back to top |
2-lunger Guest
Posted: Sun Sep 30, 2012 4:34 am Post subject: Re: rd 450 flywheel for a 560 |
Thanks for all the replies. Thanks Lee |
| Back to top |
retard Guest
Posted: Sun Sep 30, 2012 6:34 am Post subject: Re: rd 450 flywheel for a 560 |
i have a flywheel and a spacer if interested |
| Back to top |
2-lunger Guest
Posted: Sun Sep 30, 2012 4:10 pm Post subject: Re: rd 450 flywheel for a 560 |
Yes Iam interested where are you located? cell 740-818-9472 can you text me or call with info? Thanks Lee |
| Back to top |
AFTERSHOCK Regular
Posted: Mon Oct 01, 2012 4:23 am Post subject: Re: rd 450 flywheel for a 560 |
Mike @ H&H Farm Repair: (608) 332-3797. Hope this helps. I also have an adapter plate and some other parts that you may be looking for for your build. We just finished one up. Let me know if your interested.
Thanks,
Ryan |
| Back to top |
2-lunger Guest
Posted: Mon Oct 01, 2012 9:11 am Post subject: Re: rd 450 flywheel for a 560 |
Yes AFTERSHOCK I might be interested in some stuff I also would like to talk to you about the installation if that is possible my cell is on one of the posts or if you would give me yours I can get ahold of you . Calls or text is fine with me. Thanks Lee |
| Back to top |
