| Author |
Message |
bock Regular
Posted: Sat Sep 29, 2012 1:48 pm Post subject: 9400 4x4 hard to start |
have to crank it for about 10 sec. then it starts right up , is this common with these tractors it runs good other wise though |
| Back to top |
tim s Tractor Guru
Joined: 01 Nov 2008 Posts: 5943 Location: Somerset Ohio
Posted: Sat Sep 29, 2012 5:35 pm Post subject: Re: 9400 4x4 hard to start |
I had one a while back that had a bad Primer pump that allowed the fuel to leak back to the tank, made it crank too long to pick the prime up ended up replacing the primer pump assembly and took care of it... |
| Back to top |
bock Regular
Posted: Sat Sep 29, 2012 6:26 pm Post subject: Re: 9400 4x4 hard to start |
sounds like what i need to do were is it located? |
| Back to top |
41Frank New User
Posted: Sat Sep 29, 2012 6:56 pm Post subject: Re: 9400 4x4 hard to start |
I had one that you would have to push the primer to get it to start after it sat 1 day or a month. Worse yet was the torque and hp! My 1997 8400 with a chip was almost as good. It had a 24 speed, and if you did shift down at 1800 rpms, it would die on you. I replaced the check valve in the back of the head that helped some. It was dynoed and turned 410. Blockman said the fan was turning and that took the other 15 hp to give me the 425. I never could find a chip for it. If I ever won the lottery, I was going to put a REAL Detroit 12.7 in it and paint the old moter yellow and put on the back. I had 800/55/42 Trelleborg tires weighing 50K. I called it the 4 wheel drive 6030. Glad I got rid of it. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
