Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
820 identity question
Post new topic    Yesterday's Tractors Forum Index -> John Deere
russ turner
PostPosted: Sat Sep 29, 2012 4:47 pm    Post subject: 820 identity question Reply to specific post Reply with quote
I looked at an 820 s/n 2xx that had a cast bottom below the grill screen. There is 2 forward facing 4 x 4 inch flat faces facing forward on each corner. iIs this a special model, after market part for a bumper, or ??? there wasn't an 'I' with the s/n Thank you RT
bill mart
PostPosted: Sun Sep 30, 2012 5:31 am    Post subject: Re: 820 identity question Reply to specific post Reply with quote
830I front casting? bill
Rwolfejr
PostPosted: Sun Sep 30, 2012 6:42 am    Post subject: Re: 820 identity question Reply to specific post Reply with quote
That's an industrial front end. Look at your axle and see if it's flat across the bottom as well. If it is you have the industrial pan and axle assembly.
It'll look like this...
WeirdDeere
PostPosted: Sun Sep 30, 2012 3:52 pm    Post subject: Re: 820 identity question Reply to specific post Reply with quote
if the front end support you describe looks like Rwolfejr's tractor, you have an industrial front end on your 820. Really not common at all to see it on an 820. May have been retrofit on there, or possibly factory.
Brandon
russ turner
PostPosted: Sun Sep 30, 2012 4:36 pm    Post subject: Re: 820 identity question Reply to specific post Reply with quote
That"s it. I found a web site for 830 industrial with photos that also said that some 820"s had extra renforsment added to the drawbar assembly for scraper applications. The 820 in question has a much larger frame suporting the drawbar. Obtaining this one looks like it will take time, wish me luck. RT
russ turner
PostPosted: Sun Sep 30, 2012 4:38 pm    Post subject: Re: 820 identity question Reply to specific post Reply with quote
WeirdDeere
PostPosted: Mon Oct 01, 2012 12:35 am    Post subject: Re: 820 identity question Reply to specific post Reply with quote
I'd bet the drawbar looks like this?
Photobucket
Sounds like you found an interesting 820. If you get it, I'd love to see pictures! I'm the WeirdDeere.com guy
Brandon
russ turner
PostPosted: Mon Oct 01, 2012 8:54 am    Post subject: Re: 820 identity question Reply to specific post Reply with quote
Wierddeere, The hitch looks like the one in your picture. Can the wheels be moved to the narrow setting, as it is now the tractor is over width for transporting. RT
WeirdDeere
PostPosted: Mon Oct 01, 2012 10:35 am    Post subject: Re: 820 identity question Reply to specific post Reply with quote
It MIGHT be possible, depending on what rims and center hubs are on the tractor. Some hubs will allow it, others won't.
It won't be an easy job, you have to take the rims off and flip them around. If those tires are loaded, it could be a killer.
There are two hub styles. The r1600R is narrower, and you probably don't have the room to flip the rims around without hitting the fenders. My 80 won't. IF it has 16 inch wide rims you can flip it, but I think most tractors had 20 inchers. Look at the center of the hub, note how the axle retainer sticks out.
Photobucket
The R2522R hub is a little wider, and there should be enough room to flip the rims to narrow. Look at the center of the hub, note how the axle retainer is recessed slightly (ignoring the weights, couldn't find one without!)
Photobucket
Brandon
russ turner
PostPosted: Mon Oct 01, 2012 10:56 am    Post subject: Re: 820 identity question Reply to specific post Reply with quote
Weirddeere, The rims on the 820 have an inner and outer ridge for mounting wihich would narrow the width up i'm gussing about 5" per side. They might be later will fit rims. It looks like the extra drawbar brackets you pictured could be removed which would surley solve any clearance problem. Thank You RT
Rwolfejr
PostPosted: Wed Oct 03, 2012 5:19 am    Post subject: Re: 820 identity question Reply to specific post Reply with quote
Before you go to all the trouble you should look at your local laws regarding hauling farm equipment. Most likely you will be legal hauling it just the way it is. In many states moving anything farm related down a road is covered under a section called "implements of husbandry" and will usually allow for overwidth.
jd2cylman
PostPosted: Wed Oct 03, 2012 5:25 pm    Post subject: Re: 820 identity question Reply to specific post Reply with quote
Russ,
If the rims on this 820 have two ribs on them, then they must be the 34" hubs (or they're not the correct rims). For the 26" hubs, the rims only have one rib, and the rim and tire assembly get turned around to have the dish "in" or "out". In fact, I think the 34" rims were the same way. I'd have to look when I get home tomorrow. I had an 820 with 26" hubs and I sold the R1600R hubs and put on the R2522R hubs so I could use 20" rims for my new 23.1x26 tires and dish them in. Saved a lot of shed space. For the 830, Dad said no 26" tires.
Adrian
