Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
steering shaft end play
beatle
PostPosted: Sat Sep 29, 2012 4:53 pm    Post subject: steering shaft end play Reply to specific post Reply with quote
could someone please explain steering shaft end play? with the castle nut on and tight is it the play of the shaft in and out or is it as you turn the wheel left and right-slop before the wheels actually start to turn?
Berth 29 opinions
PostPosted: Sat Sep 29, 2012 5:20 pm    Post subject: Re: steering shaft end play Reply to specific post Reply with quote
I think the left right play is called lash, as opposed to in-out which should be end play.
beatle
PostPosted: Sat Sep 29, 2012 5:32 pm    Post subject: Re: steering shaft end play Reply to specific post Reply with quote
that sounds correct-how could I eliminate excess lash from the steering on an IH 130?
gene bender
PostPosted: Sat Sep 29, 2012 6:25 pm    Post subject: Re: steering shaft end play Reply to specific post Reply with quote
The end play in the shaft will be corrected by replacing the bearing behind the castle nut.
Janicholson
PostPosted: Sat Sep 29, 2012 6:57 pm    Post subject: Re: steering shaft end play Reply to specific post Reply with quote
Assuming the bearing in the worm is good, and tight in the housing: Three issues, the sector gear to worm can wear allowing real gear lash. It is not adjustable on this tractor, and is repaired with new, or good used gear/s. The second is possible wear or hogging out of the sector to shaft key, the third is the attachment of the steering arm to the shaft. if it is loose or wallowed out the same steering play can happen. Jim
gene bender
PostPosted: Sat Sep 29, 2012 7:36 pm    Post subject: Re: steering shaft end play Reply to specific post Reply with quote
You have to start at the tie rods then the out-put shaft then the inside of the sector itself bad bushings,a bearing and the key on the gear there is also a bearing in the sector along with the bushings so there is several places it can be and a little here and there adds up sometimes.
GordoSD
PostPosted: Sun Sep 30, 2012 2:07 pm    Post subject: Re: steering shaft end play Reply to specific post Reply with quote
Check the two stop rings at the yoke in front of the steering wheel they should both be snug up to the pedestal, and have two tight hex screws in them.
