| Author |
Message |
siler New User
Posted: Sat Sep 29, 2012 5:24 pm Post subject: wireing starter 165 massey |
Boy do I feel stupid on this one. I had a starter go out on a 165 massey three cyl diesel.
When I unbolted this thing I droped it and it had a black wire hooked to the solinoid short wire with the loop on one end and a metal plug on the other. I took it to a shop and he tore the starter apart and lost the wire as it was left on the starter.
Looking at whats left. I have the loop end for the battery to the starter, a small red wire which I am sure goes to the solenoid. A black wire with large loop that looks like it goes on with the battery line to the hot on starter. At first I thought it was a ground wire but the loop is big. I dont see a ground anywhere. Wondering if this thing grounds to the frame.
Also the black wire that was lost I AM SURE WENT TO THE solenoid also as I remember it. But can you believe it I cant find anywhere that it might plug into if I replace it.
I followed the harness back thinking there might be a plug and only the red and black wire inside the wire caseing.
Anybody have any ideas before I burn this thing up?
craig
And |
| Back to top |
Roy in UK Tractor Expert
Posted: Sat Sep 29, 2012 10:25 pm Post subject: Re: wireing starter 165 massey |
165 Massey three cyl diesel? That can"t be right. The MF 165 had a 4 cylinder engine. The 135 and 148 had the 3 pot. |
| Back to top |
MF#1 Regular
Posted: Sun Sep 30, 2012 6:10 am Post subject: Re: wireing starter 165 massey |
"I have the loop end for the battery to the starter, a small red wire which I am sure goes to the solenoid. A black wire with large loop that looks like it goes on with the battery line to the hot on starter. At first I thought it was a ground wire but the loop is big. I dont see a ground anywhere. Wondering if this thing grounds to the frame."
No, the starter frame is grounded to the tractor block. What you said above is correct, battery cable PLUS black wire on the HOT, red wire to the small solenoid connection. This works on most US MF diesels whether 3, 4, or even 8 cylinders. The color of the wire is variable. |
| Back to top |
siler New User
Posted: Sun Sep 30, 2012 6:32 am Post subject: Re: wireing starter 165 massey |
Ha Ha well shows what I know I always thought it was a 3 cylinder maybe its a four.
craig |
| Back to top |
siler New User
Posted: Sun Sep 30, 2012 6:34 am Post subject: Re: wireing starter 165 massey |
Thanks mf-1 thats what I thought but did not want to hook it up without asking thanks again
craig |
| Back to top |
siler New User
Posted: Wed Oct 17, 2012 12:09 pm Post subject: Re: wireing starter 165 massey |
| MF#1 wrote: | (quoted from post at 15:10:35 09/30/12) "I have the loop end for the battery to the starter, a small red wire which I am sure goes to the solenoid. A black wire with large loop that looks like it goes on with the battery line to the hot on starter. At first I thought it was a ground wire but the loop is big. I dont see a ground anywhere. Wondering if this thing grounds to the frame."
No, the starter frame is grounded to the tractor block. What you said above is correct, battery cable PLUS black wire on the HOT, red wire to the small solenoid connection. This works on most US MF diesels whether 3, 4, or even 8 cylinders. The color of the wire is variable. | Well I finnally got around to hooking it back up. Guess what new starter wont crank now im lost. The dang thing was running when the starter busted out so now not sure what to do. Checked battery and we got juice but no crank even with the new starter.
craig |
| Back to top |
Don-Wi Tractor Guru
Joined: 12 Aug 2002 Posts: 7604 Location: Hilbert, Wi
Posted: Thu Oct 18, 2012 6:24 pm Post subject: Re: wireing starter 165 massey |
Do you have the right shifter in the start position? What if you jump the terminals, the smaller one that the wire connects to, to the larger one the battery cable attatches, with a screw driver.
******** MAKE SURE IT'S OUT OF GEAR BEFORE JUMPING WITH A SCREWDRIVER!!!!!!!!***************
Donovan from Wisconsin |
| Back to top |
siler New User
Posted: Fri Oct 19, 2012 5:46 am Post subject: Re: wireing starter 165 massey |
After all the reading on neutral switches I decided to pop the cap and take a look. Low and behold there was one of the wires loose on the switch. PUt it back on and fired right up.
thanks donovan and all for the help great forum.
craig |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
