| Author |
Message |
WI-Ed Guest
Posted: Sat Sep 29, 2012 6:17 pm Post subject: Leaky Sediment Bowl |
I have a leaking sediment bowl on my Farmall H. Do I need to replace the complete assembly or is there something else I can do? Also, I noticed the end of the fuel line doesn't fit that well in the connection becasue the end seems damaged. Do I need to get a new fuel line? |
| Back to top |
David G Tractor Guru
Posted: Sat Sep 29, 2012 6:23 pm Post subject: Re: Leaky Sediment Bowl |
It all depends where it is leaking, and you can get parts to repair them. |
| Back to top |
Janicholson Tractor Guru
Joined: 30 Jan 2004 Posts: 18205 Location: St. Cloud, MN
Posted: Sun Sep 30, 2012 4:47 am Post subject: Re: Leaky Sediment Bowl |
If the body is warped,it can be attempted to be made straight, but might break. if the gasket is old, they can be found at an autoparts store for fuel tank caps, or gas cans. threads and fittings need to br very good. All these are also available right here on this sites store (tractor Parts) they are good. Jim |
| Back to top |
Greg K Long Time User
Posted: Sun Sep 30, 2012 5:10 am Post subject: Re: Leaky Sediment Bowl |
How about if it isleaking around the shaft of the shut off? I tried tightening mine up with little success. Is there some sort of packing that can be used? |
| Back to top |
teddy52food Tractor Guru
Posted: Sun Sep 30, 2012 7:01 am Post subject: Re: Leaky Sediment Bowl |
Get a tube of molycote 111 made by Dow-Corning. It is a non-hardening silicone that will seal gasoline. |
| Back to top |
Posted: Sun Sep 30, 2012 11:23 am Post subject: Re: Leaky Sediment Bowl |
Take a 2" long piece of teflon tape. Twist it into a string. Remove the packing nut from the threads, not all the way. Wrap the tape string around the shaft, and put the nut back. Do not over tighten. Jim |
| Back to top |
Paul from MI Tractor Guru
Posted: Sun Sep 30, 2012 4:59 pm Post subject: Re: Leaky Sediment Bowl |
If you have a good paint job I wouldn't mess around with it. Replacement units aren't very expensive and eliminate all the problems. Otherwise most parts are available at a good auto parts store. |
| Back to top |
sflem849 Tractor Guru
Joined: 15 Jan 2007 Posts: 5351 Location: SE Wisconsin
Posted: Sun Sep 30, 2012 5:16 pm Post subject: Re: Leaky Sediment Bowl |
| Greg K wrote: | | (quoted from post at 06:10:19 09/30/12) How about if it isleaking around the shaft of the shut off? I tried tightening mine up with little success. Is there some sort of packing that can be used? |
I use graphite packing from Menards. Works on my MD. On my first valve I took the old packing out and on my second there was some loose chewed up stuff that I took out. I left the intact part. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
