Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
4020 pto
Post new topic    Yesterday's Tractors Forum Index -> John Deere
ridgelane
PostPosted: Sat Sep 29, 2012 8:38 pm    Post subject: 4020 pto Reply to specific post Reply with quote
Hi
I'm fixing the PTO on my 4020. I've taken off the rear housing to replace the seal and O rings in the pto. The piece, referred to in the online parts catalog as the guide, part number R33855, has two grooves in it. I assume they are worn there by the seal. Can this be repaired in any fashion or is a new one in order? I'm told a new one is just under $500.00. Not sure I want to spend that much unless there is no other way.
wisbaker
PostPosted: Sat Sep 29, 2012 9:52 pm    Post subject: Re: 4020 pto Reply to specific post Reply with quote
You might be able to get a "speedy sleeve" that'll go over the journal where the wear is, take you new seals to a bearing/power train house and ask them. A sleeve is a very thin bushing you slid over the shaft and usually epoxy in place. It provides a new surface for the seal to work against
ridgelane
PostPosted: Sat Sep 29, 2012 9:56 pm    Post subject: Re: 4020 pto Reply to specific post Reply with quote
Thanks,, should be a little cheaper too.
Tx Jim
PostPosted: Sun Sep 30, 2012 2:46 am    Post subject: Re: 4020 pto Reply to specific post Reply with quote
Local JD dealers shows that part at R33855 PILOT,REAR POWER SHAFT ADD 382.53 USD
A&I shows it at A-R33855 GUIDE, PTO ADD 162.50 USD
If a correct size "speedy sleeve" is unobtainable you might try a salvage yard.
Cliff Nelson
PostPosted: Sun Sep 30, 2012 6:01 am    Post subject: Re: 4020 pto Reply to specific post Reply with quote
The new seal is narrower than the bore in the housing allowing you to locate the seal slightly different than original. Measure the distance to the wear marks on the shaft then measure to the lips on the new seal. Usually you can shift the seal about 1/8" to place it on a smooth area of the guide. If someone has already done this before it may not work. I have not tried a speedi sleeve but it should work also.
tim s
PostPosted: Sun Sep 30, 2012 6:18 am    Post subject: Re: 4020 pto Reply to specific post Reply with quote
I have considered Speedi Sleeves, and even had the dimensions wrote down here some where Darn it (I was going to share them with you)I think the cost of them would be around $45, they are pricey, but way cheaper than a new part,,I always thought it was odd that that area would wear so badly... Another thing was brought up on here by some one a while back when speaking of seals, was un-doing the garter spring and re-tieing it a bit tighter..some thing that I had never thought of before...
wisbaker
PostPosted: Sun Sep 30, 2012 9:25 am    Post subject: Re: 4020 pto Reply to specific post Reply with quote
Sometimes the wear on a shaft is not from the seal but the dirt & crap that get lodged there by the seal, especially if it's oil. The seal holds it against the spinning shaft
tim s
PostPosted: Sun Sep 30, 2012 9:37 am    Post subject: Re: 4020 pto Reply to specific post Reply with quote
True, and that rear PTO seal sees a lot of dirt and grime....
TIMAR
PostPosted: Sun Sep 30, 2012 1:12 pm    Post subject: Re: 4020 pto Reply to specific post Reply with quote
The SPEEDY SLEEVE works great. have done several that way.
