Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
wheel bolts to drive in wheel studs?
Post new topic    Yesterday's Tractors Forum Index -> Implement Alley
workhorse66
PostPosted: Sun Sep 30, 2012 7:14 am    Post subject: wheel bolts to drive in wheel studs? Reply to specific post Reply with quote
The threads on the hub are worn and lug bolts won't stay tight on gravity wagon gear is there a drive in stud out there to convert these over to lug nuts without re drilling the hub? just drive into existing threads? Does nappa or mutual wheel make a reto kit?
DeltaRed
PostPosted: Sun Sep 30, 2012 7:44 am    Post subject: Re: wheel bolts to drive in wheel studs? Reply to specific post Reply with quote
Not that Iam aware of..But it doesnt take much to drill/ream out the holes on a cast hub.
RayP(MI)
PostPosted: Sun Sep 30, 2012 8:27 am    Post subject: Re: wheel bolts to drive in wheel studs? Reply to specific post Reply with quote
I would try bolts with the same diameter and thread, run them in from the backside, if there"s enough room. Probably enough thread to hold them in, and head against hub willl prevent pull out.
OH - 961
PostPosted: Sun Sep 30, 2012 9:33 am    Post subject: Re: wheel bolts to drive in wheel studs? Reply to specific post Reply with quote
And a generous dab of red Loctite to keep them in place!
Myron
JMS./MN
PostPosted: Sun Sep 30, 2012 9:52 am    Post subject: Re: wheel bolts to drive in wheel studs? Reply to specific post Reply with quote
Get longer wheel bolts and put a nut on the back side of the hub.
wisbaker
PostPosted: Sun Sep 30, 2012 10:18 am    Post subject: Re: wheel bolts to drive in wheel studs? Reply to specific post Reply with quote
Probably wouldn't be that hard to find hubs to fit your spindles and switch them over that way. I don't know how much experience you have fixing stuff I'll share a few thoughts-drilling or reaming them for studs sounds like a sound idea but getting the new larger holes exactly where they are supposed to be could be difficult,if they're a bit off your wheel may not be centered and it's going to hop when you pull it at any speed, this might be a job for a machine shop and someone still has to figure out if the hub has enough meat to bore out the stud holes and not get weakened in the process. Bolts through from the backside may have merits, just make sure the bolts you use are as good or better than wheel studs or lug bolts or you could have wheels flying off, there's never a good time for that. I guess I'm saying the safest way is new hubs, from there it's your wagon, you know how much weight you haul, how fast and far you pull it, how much your cargo is worth, how much you have to loose if the patched hub fails and injures someone and your risk tolerance.
Michael Soldan
PostPosted: Sun Sep 30, 2012 11:28 am    Post subject: Re: wheel bolts to drive in wheel studs? Reply to specific post Reply with quote
I ran into that witha running gear,I got new studs at Napa but the holes were worn just enough that the studs would turn when you tightened the lug nuts,we just spot welded the back of them,they been on that wagon like that for over twenty years
evilboweviel
PostPosted: Sun Sep 30, 2012 11:53 am    Post subject: Re: wheel bolts to drive in wheel studs? Reply to specific post Reply with quote
sounds like time to helicoil the hubs
thurlow
PostPosted: Sun Sep 30, 2012 1:30 pm    Post subject: Re: wheel bolts to drive in wheel studs? Reply to specific post Reply with quote
Have fixed many-a-one by doing that, sticking a stud through from the back and nickel welding it in.
Leroy
PostPosted: Sun Sep 30, 2012 5:48 pm    Post subject: Re: wheel bolts to drive in wheel studs? Reply to specific post Reply with quote
That is what I have done.
JMS./MN
PostPosted: Mon Oct 01, 2012 10:33 pm    Post subject: Re: wheel bolts to drive in wheel studs? Reply to specific post Reply with quote
Only bugger is to remember there is a nut on the backside when unbolting!!!! Did that on the loader tractor years ago....also a Gleaner F2 combine.....so as long as I remember those two machines.....ok to go!
Post new topic    Yesterday's Tractors Forum Index -> Implement Alley All times are GMT - 8 Hours
