5310 won't start
ALAND
PostPosted: Sun Sep 30, 2012 7:35 am    Post subject: 5310 won't start Reply to specific post Reply with quote
Hey guys I have a Deere 5310 that won"t start.
When I turn the key switch I get nothing. I tried
to jumper across the seat safety and still
nothing. I assume there has to be a neutral
safety switch also but can"t find where it is.
Does anyone have a wiring diagram they could
post? Any suggestions?
Tx Jim
PostPosted: Sun Sep 30, 2012 8:07 am    Post subject: Re: 5310 won't start Reply to specific post Reply with quote
Will headlights and idiot lights come on??????? Have you checked for blown fuses???
ALAND
PostPosted: Sun Sep 30, 2012 8:58 am    Post subject: Re: 5310 won't start Reply to specific post Reply with quote
Yep checked the fuses. Lights work. Dash
light come on when I turn the key. Good
battery. Checked he connections at the battery,
starter and ground. Not getting voltage to the
selenoid.
Tx Jim
PostPosted: Sun Sep 30, 2012 9:23 am    Post subject: Re: 5310 won't start Reply to specific post Reply with quote
Parts key #14 RE39116 SWITCH KIT, NEUTRAL START ADD 37.94 USD
JD5210
PostPosted: Sun Sep 30, 2012 3:18 pm    Post subject: Re: 5310 won't start Reply to specific post Reply with quote
Check that power is coming out of wire 571 on the key switch then check PTO switch, neutral switch (on gear level), if you have power to this point, then check the start relay.
The seat switch does NOT affect starting on the 5X10 tractors.
ALAND
PostPosted: Thu Oct 04, 2012 6:03 am    Post subject: Re: 5310 won't start Reply to specific post Reply with quote
Thanks for the help guys. Turns out is was the neutral safety switch. Got if fixed and running again. Man that switch is hard to get too. Had to take off the fender and platform sheet metal to get to it. That was 75% of the job.
Thanks again for the help.
Alan
