| Author |
Message |
redjohn Regular
Posted: Sun Sep 30, 2012 9:46 am Post subject: gerator oil pump on 1066 |
First I want to thank the people who responded to my priming a diesel question.
I made sure there was fuel in both fuel filters, and it ran down to the injector.
I cracked the injector lines, then decided to crank the motor over, instead of pumping on the injector.
While cranking, I watched the oil pressure gauge. The gauge pressure never came up.
For those of you who didn't read my other listing, this tractor was in a fire, so the motor (1466 motor) was rebuilt. I rewired the tractor, with a wiring harness kit, and re painted the tractor.
My question is, what does it take, or what should have been done with the gerator oil pump, as far as if it needed priming befor installing in motor, or what.
I'm pretty good with a wrench, and have done alot of overhauls, just not diesels. I had a very good book on the rebuild. It was the IHC service manual for 3 and 400 series diesel engines.
I'm nervous about cranking the motor over with no oil pressure and having it start.
Before you ask, yes there is oil in the crankcase.
Just checked the book, and am wondering if the pressure regulator may be bad, possible melting from the fire?
I'm open to suggestions |
| Back to top |
Janicholson Tractor Guru
Joined: 30 Jan 2004 Posts: 18457 Location: St. Cloud, MN
Posted: Sun Sep 30, 2012 12:25 pm Post subject: Re: gerator oil pump on 1066 |
Filling the system with oil can be done easily with a pump oil can. Use a bit of vinyl hose, or rubber to make a connection from the spout to the oil pressure sending threads in the block. Put engine oil in the can, and pump till it feels like you have more difficulty pumping. (it might take 3 cans of oil or many more if the filter is not full). this primes the system and assures at least a high probability of pressure. Jim |
| Back to top |
buzzinduzzin Regular
Posted: Sun Sep 30, 2012 4:40 pm Post subject: Re: gerator oil pump on 1066 |
sometimes with that style of pump it takes more than cranking r.p.m. to get the pump going |
| Back to top |
Owen Aaland Tractor Expert
Joined: 14 Feb 2007 Posts: 3019 Location: Zumbrota MN
Posted: Sun Sep 30, 2012 10:01 pm Post subject: Re: gerator oil pump on 1066 |
There is a lot of oil galley area fill before you will see any oil pressure. Filling the oil filters before installing them helps but you still have the oil cooler and all the block galleys to fill. The best is to pressure bleed the oil system before you start. I usually install 2 - 3 gallons through my pressure bleeder before cranking the engine. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
