| Author |
Message |
Geo 2 Ns Guest
Posted: Sun Sep 30, 2012 1:02 pm Post subject: installe vale guides tips |
is ther any tips to installe the valve guides into the block.never had to install this type before.thanks for any advise.good site I enjoy reading the info |
| Back to top |
Geo 2 Ns Guest
Posted: Sun Sep 30, 2012 1:07 pm Post subject: Re: installe vale guides tips |
sorry up
date info 1949 8N front dist ref to engine intake and exhaust valves guides |
| Back to top |
JCinKY Regular
Posted: Sun Sep 30, 2012 2:56 pm Post subject: Re: installe vale guides tips |
| Geo 2 Ns wrote: | (quoted from post at 14:07:12 09/30/12) sorry up
Geo...valve guides are installed "under" the valve spring and seated on the valve stem, held in place with two keepers. Seals are offered for both intake and exhaust. I use seals on both, some say forget em on exhausts.
You install the valve, guide, spring as one unit into the corresponding holes in the block. Just line em up and tap em in. Held in place with keepers. clear as mud, eh. Post back with any q's.
-Jeff |
| Back to top |
tn8n Regular
Joined: 23 Oct 2011 Posts: 114 Location: Knoxville, TN
Posted: Sun Sep 30, 2012 3:57 pm Post subject: Re: installe vale guides tips |
| Geo 2 Ns wrote: | | (quoted from post at 14:02:37 09/30/12) is ther any tips to installe the valve guides into the block.never had to install this type before.thanks for any advise.good site I enjoy reading the info |
are you using the rotating type exhaust valves? are the guides solid or two piece? one of the gurus will give you a much better response than i can, but for now..
lube them up good and be easy when you press them down into the block so you don't tear the seals. assemble the valves, and install them from above, (top of block.) reach in through the intake and exhaust port to press the guide down enough to get the keeper on, then push it up until the keeper is seated in the block. most people grind a flat screwdriver to do the prying with. search around this site for a pic of what to do. i followed their directions and it worked great! |
| Back to top |
Geo 2 Ns Guest
Posted: Mon Oct 01, 2012 5:43 am Post subject: Re: installe vale guides tips |
Thanks guys for the info just wanted to be sure the was no hidden little tricks that I should whatch out for.
thanks agin have A good week
george 2 8NS |
| Back to top |
Geo 2 Ns Guest
Posted: Tue Oct 02, 2012 4:08 am Post subject: Re: installe vale guides tips |
THANKS FOR THE INFO WILL PUT THEM IN TIS AFTERNOON WHEN i GET HOME FROM DOC
THANKS AGAIN GEO |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
