Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
12v Headlight wiring
Post new topic    Yesterday's Tractors Forum Index -> Ford 9N, 2N, 8N
Duke83
PostPosted: Sun Sep 30, 2012 1:57 pm    Post subject: 12v Headlight wiring Reply to specific post Reply with quote
Does anyone have a diagram for wiring headlights for a 12v system. When i bought my 1948 8n the headlights were not wired. Just want to make sure I do it right. Thanks
Royse
PostPosted: Sun Sep 30, 2012 2:29 pm    Post subject: Re: 12v Headlight wiring Reply to specific post Reply with quote
JMOR has them on his wiring diagrams if you search for those.
Pretty easy, just hook from the battery post of your resistor to the light
switch, then to the lights.
You don't want to hook to the side of the resistor shut off by the key.
It may sound good but the switch can't handle the current flow.
Duke83
PostPosted: Sun Sep 30, 2012 2:34 pm    Post subject: Re: 12v Headlight wiring Reply to specific post Reply with quote
Thanks, that sounds easy enough.
Charles Krammin
PostPosted: Sun Sep 30, 2012 3:43 pm    Post subject: Re: 12v Headlight wiring Reply to specific post Reply with quote
Are the bulbs new 12 volt or original 6 volt?
original 6 volt would have to be wired in series (12 volt in to one light terminal, out the other light terminal, to next ligght terminal and last trminal to ground. It takes the resistance of 2 6 volt bulbs to equal 1 12 volt bulb.
New 12 volt bulbs are hooked 12 volt to ground in each light holder.
Charles Krammin SW MI
DON TX
PostPosted: Sun Sep 30, 2012 5:52 pm    Post subject: Re: 12v Headlight wiring Reply to specific post Reply with quote
Most recommend running a ground wire to the headlight to the frame due to paint, rust and corrosion issues to the sheet metal. HTH
DON TX
ASEguy
PostPosted: Mon Oct 01, 2012 3:09 am    Post subject: Re: 12v Headlight wiring Reply to specific post Reply with quote
You might want to add an in-line fuse as well.
souNdguy
PostPosted: Mon Oct 01, 2012 5:29 am    Post subject: Re: 12v Headlight wiring Reply to specific post Reply with quote
no diagram needed. lamps ar ethe most basic circuit you can get.
brab power same palce ignition does.. use a fused switch of correct amperage.. run wire to lmaps, ground lamps. sheetmetal may not be a good ground...
