| Author |
Message |
Ron O'Harold New User
Posted: Sun Sep 30, 2012 2:34 pm Post subject: 8N 12volt won't start |
I just bought an 8N ford that ran when I bought it. Keep in mind that this is my first tractor and the wiring was in very poor condition. I replaced the wiring and now it won't start. I have a spark at the plugs and I know its getting fuel. I also replaced the battery and plugs (set at .025). Can anyone give me an idea on what to look at? |
| Back to top |
JMOR Tractor Guru
Posted: Sun Sep 30, 2012 2:39 pm Post subject: Re: 8N 12volt won't start |
| Ron O'Harold wrote: | | (quoted from post at 18:34:05 09/30/12) I just bought an 8N ford that ran when I bought it. Keep in mind that this is my first tractor and the wiring was in very poor condition. I replaced the wiring and now it won't start. I have a spark at the plugs and I know its getting fuel. I also replaced the battery and plugs (set at .025). Can anyone give me an idea on what to look at? | It was running. You replaced all the wiring. Now, it won't start. Answer: you didn't connect all the wires correctly. Review all the wiring. |
| Back to top |
ron oharold New User
Posted: Sun Sep 30, 2012 2:47 pm Post subject: Re: 8N 12volt won't start |
I checked all the terminals with a 12 volt light and I have power at every terminal when turning over engine. |
| Back to top |
JMOR Tractor Guru
Posted: Sun Sep 30, 2012 2:50 pm Post subject: Re: 8N 12volt won't start |
| ron oharold wrote: | | (quoted from post at 18:47:57 09/30/12) I checked all the terminals with a 12 volt light and I have power at every terminal when turning over engine. | If side mount/round can coil, then put test light on coil terminal wired to distributor & see if it blinks on/off during cranking, with ignition on |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50436 Location: Lake of the Ozarks area of MO
Posted: Sun Sep 30, 2012 3:28 pm Post subject: Re: 8N 12volt won't start |
Do a simple hot wire from the ignition side of the battery to the coil ignition side and see if it starts. If it does then you got your wiring wrong |
| Back to top |
Bruce (VA) Tractor Guru
Joined: 24 Feb 2003 Posts: 11268 Location: Old Church VA
Posted: Sun Sep 30, 2012 3:32 pm Post subject: Re: 8N 12volt won't start |
As JMOR said, you wired it wrong.
The fact that a light bulb comes on doesn't tell you how much actual voltage you have. That's why meters were invented. ( see tip # 47)
It is important for you to tell us if the distributor is on the front of the engine or on the side. The troubleshooting is different based upon the configuration of your engine.
It takes three things for an engine to run: spark at the right time, compression, & fuel in the right mixture. For the moment, forget about compression & concentrate on narrowing the problem down to spark or fuel.
There are three very important tools you always need to have in your N tool box: a 3 inch piece of wire w/ alligator clips on each end, an old spark plug w/ the gap opened to at least 3/16” ( ¼” is better) and a 7/16 box end wrench. (see tip # 50 at the link below) And, you really do need a working ammeter on the tractor; it is a very important diagnostic tool. With these tools, you can quickly narrow down most N problems to spark or fuel.
First, check for fuel. Get a can & put it under the carb. Remove the bolt in the bottom of the carb; as long as the fuel is turned on, you should see gas flowing out of the carb. Let it run for at least 30 seconds. If it’s a dribble, or runs for 5 seconds & stops, or none at all, you have solved half the problem: it’s fuel related. If gas flows well out of the carb & only stops when you turn it off at the sediment bowl, chances are very good it’s not a fuel problem. So, next, turn the key on, crank the engine & look at the ammeter. What is the needle doing? Does it show a constant discharge, no movement at all, or does it move back & forth slightly? Next, get the old plug, ground it to a rust & paint free spot on the engine, turn the key on & crank the engine. If the spark jumps the 3/16” gap, you probably don’t have a spark problem. If it won’t jump the 3/16” gap, you have a spark problem. If the ammeter needle shows a constant discharge, or doesn’t move at all, that also tells you that you have a spark problem. Jump the ignition switch w/ your jumper wire & see what happens. If it runs, you found the problem. If it doesn’t have spark after you jump the ignition switch, post back for more info on further troubleshooting. (and do not forget to turn the ignition switch off; see tip # 3
If it does not have gas coming out of the carb at a steady stream w/ the bolt out for at least 30 seconds, you have a fuel problem. First, remove the gas cap. Your vent could be clogged & it vacuum locked. If that doesn’t work, tap the carb bowl w/ a hammer handle in case the float is sticking closed. (don’t whack it w/ the head of the hammer; you can crack the bowl). If you still don’t see gas flowing, the N has three fuel screens; one in the brass elbow, one in the top of the sediment bowl & one on the stem of the sediment bowl in the gas tank. Check the screen in the elbow & the screen in the top of the sediment bowl. (don’t worry about the one in the tank) Both probably need to be cleaned. If you have the fuel knob turned on all the way, & 1 gallon or less in the tank, it may be trying to feed off of the reserve inlet which is probably clogged. Only open it 2 full turns. Put at least 2 gallons in the tank. (and do not forget to turn the gas off; see tip # 9)
There are ways to check for spark & fuel that work & ways that don't. For example, having gas to the carb is nice, but having it past the float is what counts! That’s why removing the 7/16” bolt in the bottom of the carb is the way to check for fuel. And, same thing w/ spark at the plugs. Some folks think that checking for spark means pulling a plug wire off & looking for one. Well, it's the distance the spark jumps at the plug that gives you the info you want. It takes about 17kv to jump a 3/16" gap & 22kv to jump ¼” in the open air. Remember, it’s 14psi outside of the engine & about 90psi at a 6:1 compression ratio in the cylinders & compressed air creates electrical resistance, so you really need the 17-22kv to fire the plugs when the engine is running. A store bought plug checker will work better than an old plug because it won’t shock the snot out of you like an old plug might!
50 Tips
| Back to top |
souNdguy Tractor Guru
Posted: Mon Oct 01, 2012 5:03 am Post subject: Re: 8N 12volt won't start |
if that's true.. then you have open points... |
| Back to top |
Posted: Mon Oct 01, 2012 12:05 pm Post subject: Re: 8N 12volt won't start |
Don't know what happened, but when I went out today it started right up. Go figure. appreciate all your help though. |
| Back to top |
R Geiger Tractor Expert
Joined: 19 Apr 2009 Posts: 1772 Location: Banks, Oregon
Posted: Mon Oct 01, 2012 12:19 pm Post subject: Re: 8N 12volt won't start |
| ron oharold wrote: | | (quoted from post at 05:05:46 10/02/12) Don't know what happened, but when I went out today it started right up. Go figure. appreciate all your help though. |
You probably flooded it the last time. That happens! |
| Back to top |
old Tractor Guru
Posted: Mon Oct 01, 2012 1:35 pm Post subject: Re: 8N 12volt won't start |
You probably had it flooded and by letting it sit the flooded condition fixed it self |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
