930CK '64 wheel tread widening?
AKAnanuk
PostPosted: Sun Sep 30, 2012 6:37 pm    Post subject: 930CK '64 wheel tread widening? Reply to specific post Reply with quote
Hi
Can the wheels be reversed to give a wider stance/tread on the "64 930CK"s?
Just by looking at the parts manual, and the tractor itself, it looks doable.
I"d like to get a little more distance between the rears to straddle the hay windrow better.
thanks in advance!
casecollectorsc
PostPosted: Mon Oct 01, 2012 5:56 am    Post subject: Re: 930CK '64 wheel tread widening? Reply to specific post Reply with quote
Can't be reversed as the axle is tapered. they are a standard tread tractor, nonadjustable.
AKAnanuk
PostPosted: Mon Oct 01, 2012 10:17 pm    Post subject: Re: 930CK '64 wheel tread widening? Reply to specific post Reply with quote
Can the rims be flipped so the ridge is on the inside?
that would gain about 6 inches....
casecollectorsc
PostPosted: Tue Oct 02, 2012 5:41 am    Post subject: Re: 930CK '64 wheel tread widening? Reply to specific post Reply with quote
No, the rim uses the cast center as the backstop for the rim. Where the wheel locks are only gives one option for the rims to fit in place.
Jimmie D. Phelps
PostPosted: Tue Oct 02, 2012 7:10 am    Post subject: Re: 930CK '64 wheel tread widening? Reply to specific post Reply with quote
Use rim mounted duals, take off the inside tire and you have a wide stance. BUT be prepared to break axles as it will do that over and over again. From 500 to 930 six speed , if dualed it will break axles.
Jimmie D. Phelps
PostPosted: Tue Oct 02, 2012 7:11 am    Post subject: Re: 930CK '64 wheel tread widening? Reply to specific post Reply with quote
