Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
heating on flathead ford v8
Goto page 1, 2, 3  Next
Post new topic    Yesterday's Tractors Forum Index -> Ford
Charles Canady
PostPosted: Mon Oct 01, 2012 9:59 am    Post subject: heating on flathead ford v8 Reply to specific post Reply with quote
I have installed a flathead ford v8 on a 8n tractor but I have a heating problem can anyone give me some help
D7fever
PostPosted: Mon Oct 01, 2012 10:23 am    Post subject: Re: heating on flathead ford v8 Reply to specific post Reply with quote
What type of heating problem, too hot, or too cold
souNdguy
PostPosted: Mon Oct 01, 2012 10:31 am    Post subject: Re: heating on flathead ford v8 Reply to specific post Reply with quote
heating problem as in it overheats?
what tstat you running? what radiator?
shroud?
pump int he v8 good and moving water?
JMOR
PostPosted: Mon Oct 01, 2012 10:40 am    Post subject: Re: heating on flathead ford v8 Reply to specific post Reply with quote
Charles Canady wrote:
(quoted from post at 13:59:25 10/01/12) I have installed a flathead ford v8 on a 8n tractor but I have a heating problem can anyone give me some help
Oversized radiator installed? Good fan & shroud? Maybe electric fan?
Charles Canady
PostPosted: Mon Oct 01, 2012 10:41 am    Post subject: Re: heating on flathead ford v8 Reply to specific post Reply with quote
it is running to hot
Charles Canady
PostPosted: Mon Oct 01, 2012 10:43 am    Post subject: Re: heating on flathead ford v8 Reply to specific post Reply with quote
used ford 4 tube radiator with elec. fan
new water pumps. water moving fast in raditor
JMOR
PostPosted: Mon Oct 01, 2012 10:57 am    Post subject: Re: heating on flathead ford v8 Reply to specific post Reply with quote
(quoted from post at 14:43:13 10/01/12) used ford 4 tube radiator with elec. fan
Is that larger than N radiator? You know that the larger engine produces more heat. Retarded engine timing will put more heat into cooling system......might check static & advance mechanism(s).
old
PostPosted: Mon Oct 01, 2012 11:07 am    Post subject: Re: heating on flathead ford v8 Reply to specific post Reply with quote
Does it have a thermostat installed in it??? If not that could well be your problem due to the fact the coolant does not have time enough to cool before it goes back into the engine so yep it runs to hot
souNdguy
PostPosted: Mon Oct 01, 2012 11:16 am    Post subject: Re: heating on flathead ford v8 Reply to specific post Reply with quote
lean will make em hot too....make them manifolds glow.. Smile
JMOR
PostPosted: Mon Oct 01, 2012 11:23 am    Post subject: Re: heating on flathead ford v8 Reply to specific post Reply with quote
old wrote:
(quoted from post at 15:07:52 10/01/12) Does it have a thermostat installed in it??? If not that could well be your problem due to the fact the coolant does not have time enough to cool before it goes back into the engine so yep it runs to hot
Sorry, but you can not demonstrate that theory.
russ1
PostPosted: Mon Oct 01, 2012 11:33 am    Post subject: Re: heating on flathead ford v8 Reply to specific post Reply with quote
Old is correct. These flatheads with two water pumps need thermostats to prevent overheating, otherwise the water flow through the radiator is too fast.
JMOR
PostPosted: Mon Oct 01, 2012 11:38 am    Post subject: Re: heating on flathead ford v8 Reply to specific post Reply with quote
russ1 wrote:
(quoted from post at 15:33:27 10/01/12) Old is correct. These flatheads with two water pumps need thermostats to prevent overheating, otherwise the water flow through the radiator is too fast.
Sorry, but you can not demonstrate that theory, either.
sotxbill
PostPosted: Mon Oct 01, 2012 12:03 pm    Post subject: Re: heating on flathead ford v8 Reply to specific post Reply with quote
It may be the thermostats make sure that EACH side gets the correct amount of LIMITED flow so that one side does not overwhelm or push back the other side. Would do no good to have one side running at 90 degrees and the other at 250 degrees due to unequal water flow.
D7fever
PostPosted: Mon Oct 01, 2012 5:01 pm    Post subject: Re: heating on flathead ford v8 Reply to specific post Reply with quote
put a thermostat on each side, or put a 1/2 inch washer in the hose where the thermostat is supposed to go , have to have some sort of restriction, or the water will move thru the radiator too fast and it can't cool. in a truck or car those v8s' need about 20 to 22 quarts to fill the system, if your radiator is too small it won't cool. Also if your timing is not right it will heat up.
Which engine do you have, 59AB oe an 8BA ?
you do not have a bad head gasket or cracked head or block do you?
Good luck.
36 Coupe
PostPosted: Mon Oct 01, 2012 5:29 pm    Post subject: Re: heating on flathead ford v8 Reply to specific post Reply with quote
I have proved that with a Model A FORD powering a cord wood saw.No thermostat boil over,install a thermostat boiling stops.
Page 1 of 3
