| Author |
Message |
JohnDeereM50 Regular
Posted: Mon Oct 01, 2012 5:33 pm Post subject: JD Paint ?'s |
Wondering what is the best paint I can use when I get to the point of painting my 1950 M JD? I"m done with the cheap stuff that I have been using for years.
I know there is a ton of options and I want to do it right the first time and have shiny paint for years to come.
I"m wanting to go with a single stage Urethane. I think I can get PPG and Dupont at Napa. I have no ideas what the paint codes are for either. I expect to pay alot of money for good paint so that won"t scare me away. Just getting ideas. I may start peddlin with painting some small things. Thanks for any help. |
| Back to top |
Posted: Mon Oct 01, 2012 5:39 pm Post subject: Re: JD Paint ?'s |
I'm open to bc/cc also...i use the cheap line of it at work. I've read the single stage urethane can be clear coated which sounds like the best option or maybe not clear it at all? |
| Back to top |
thesmoothedeere Long Time User
Posted: Mon Oct 01, 2012 5:51 pm Post subject: Re: JD Paint ?'s |
Research some past threads on here. Tons of info in archives. U'll need full fresh air mask going into the harder paints. |
| Back to top |
Ray Tractor Guru
Posted: Mon Oct 01, 2012 6:49 pm Post subject: Re: JD Paint ?'s |
John deere paint will last a long time if you use hardner.Never saw any automotive paint that would match the JD color. |
| Back to top |
Posted: Mon Oct 01, 2012 6:59 pm Post subject: Re: JD Paint ?'s |
I will add my two cents since the The Smoothed Deere is painted in the "Cheap Stuff" Even the Motherdeere paints will look brand new if waxed and kept outta direct sun. My tractor still looks pretty shiny and it's been 6 years on the repaint. It does chip easier but when u use a really good primer it seems to help. |
| Back to top |
M-MAN Long Time User
Posted: Mon Oct 01, 2012 8:37 pm Post subject: Re: JD Paint ?'s |
The single stage urethane doesn't need a clearcoat. FIT has posted the paint codes in PPG & Dupont if you'll search the archives. |
| Back to top |
Dave H Long Time User
Posted: Tue Oct 02, 2012 2:12 am Post subject: Re: JD Paint ?'s |
I am curently a fan of the Nason line in DuPont (I think it is DuPont, but Nason for sure). It has been a while.
you can get that stuff locally thru ORilleys. |
| Back to top |
ArnieinChesterfieldVa Regular
Joined: 09 Nov 2009 Posts: 342 Location: Chesterfield co., Va
Posted: Tue Oct 02, 2012 5:55 pm Post subject: Re: JD Paint ?'s |
I've thrown these questions at folks over the past couple of years too about the paints. The conclusion I've come upon (might save ya some time) is one thing to be fearful of using anything except the authentic John Deere paint from the dealer is they like to take on a bluish tint after a period of time. Apparently the good dealer paint will not do that. I've seen a couple at shows that have turned that bluish tint....not a pretty sight. JMHO
Arnie |
| Back to top |
David G Tractor Guru
Posted: Tue Oct 02, 2012 6:41 pm Post subject: Re: JD Paint ?'s |
I have been painting everything with NAPA urethane and am pleased. It goes on well and dries hard. I would recommend 3 coats if you really want it to look nice. |
| Back to top |
Cockbird_Hunter Regular
Posted: Wed Oct 03, 2012 3:33 am Post subject: Re: JD Paint ?'s |
From a technical chemistry view, John Deere dealership paint is modified alkyd enamel and offers the POOREST UV protection/fade resistance of any paint line. It's 1930's technology@!!! Also, hardener has nothing to do with improving UV/fade resistance.
My suggestion would be to do an experiment, for I have. I painted two implements, one with dealership paint & one with automotive single stage urethane & left them outside for six months. RESULTS: Dealership paint faded significantly & no change in the urethane.
I suppose dealership paint is fine if you never take you equipment out of the shed.....!
PPG, Dupont, Sikkens, 3M, and other leading paint manufactures distribute paints that match John Deere green & yellow well. You just need to do your homework!
The attached was painted (1 piece at a time) w/ PPG products.
| Back to top |
Texasmark1 Tractor Expert
Posted: Wed Oct 03, 2012 5:15 am Post subject: Re: JD Paint ?'s |
Problem I had with trying to buy it was the yellow. Not all paint with the JD Yellow label is canary yellow. Some of it has a golden tint to it and it is obvious that it is not JD.
Mark |
| Back to top |
