| Author |
Message |
Farmallb Long Time User
Posted: Mon Oct 01, 2012 5:46 pm Post subject: needing print out of BS 19? engine |
Flywheel and shaft is smooth. Shaft is tapered. How do I go bout timing the flywheel to the shaft. Please give me a exploded printout I can look at. Thanks. |
| Back to top |
joe csuti Long Time User
Posted: Tue Oct 02, 2012 2:52 am Post subject: Re: needing print out of BS 19? engine |
What style ign system on eng?The mod#19 eng used 2 different systems depending on age of eng.
One system had coil mounted OVER flywheel & used a tab on face of flywheel to set flywheel timing,other system was the magna-matic with a rotor mounted on crank & coil UNDER flywheel,on this system the magnet rotor is clamped to crank & keyed to shaft with a woodruff key,ign timing is set by moving plate with coil on it & matching set mark to eng mod# on rotor,the flywheel is held by crank/flywheel taper & flywheel nut and has no effect on ign timing,if you have this system check crank very carefully,woodruff key may be sheared flush with shaft. |
| Back to top |
greygoat Tractor Expert
Posted: Tue Oct 02, 2012 5:20 am Post subject: Re: needing print out of BS 19? engine |
There's a FREE download someplace..I'll send
web address if I find it.
greygoat |
| Back to top |
Posted: Tue Oct 02, 2012 9:52 am Post subject: Re: needing print out of BS 19? engine |
Joe, How ya doin? Say, would you please send me the print out you did before. Its the B&S on a Simplicity walk behind garden tractor with the tapered shaft with no key way. Thanks ALOT. |
| Back to top |
Posted: Tue Oct 02, 2012 10:28 am Post subject: Re: needing print out of BS 19? engine |
Goto link below,after you download put mouse pointer over pic/text,same will change to a magnifying glass with a + in center,click left mouse button to enlarge,if your browser doesn't support this feature,try a different browser.The link below is for ign system with coil OVER flywheel & key tab on face of flywheel,IF maga-matic system under flywheel then flywheel timing isn't an issue,there may/may not be a key tab on flywheel on this system,briggs manual only shows how to remove flywheel & makes no mention or shows key tab,flywheel & crank may just be a taper lock held with flywheel nut,I had a mod 23 yrs ago with magna-matic system but never had a problem with same or need to pull flywheel cover,so I don't know for sure if there's a key tab to lock flywheel.
flywheel
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
