| Author |
Message |
Old Bob Regular
Posted: Mon Oct 01, 2012 6:50 pm Post subject: Super 88 |
I have a Super 88. A nice tractor. Not started in probably 4 years. Put a battery in it today and it was stuck. Oil still looks great and radiator is still full to the top. I am a JD guy, and have never attempted to loosen up an Oliver. What are my best options to remedy this??? Thanks in advance. Old Bob |
| Back to top |
sdc eastern ia Regular
Posted: Tue Oct 02, 2012 5:43 am Post subject: Re: Super 88 |
Do not pull it and pop the clutch. You will bend a rod or two. Fixing my problem now as we speak. |
| Back to top |
Posted: Tue Oct 02, 2012 5:53 am Post subject: Re: Super 88 |
Try tranny fluid and diesel fuel mix or penetrating fluid, let it sit a few then use a breaker bar on the front nut. Not a lot of pressure or you will ruin the threads in the crank. All else pull the head. This may well be the first thing you need to do. |
| Back to top |
gordey Long Time User
Posted: Tue Oct 02, 2012 9:37 am Post subject: Re: Super 88 |
If its a diesel, you will need to free the injection pump as well. |
| Back to top |
Mike (WA) Tractor Guru
Posted: Tue Oct 02, 2012 10:23 am Post subject: Re: Super 88 |
Or put the magic elixer in the cylinders, leave the tractor in gear, and then just rock the back wheel a little, both ways, every time you walk by it. May take a couple of weeks, but it will probably free up. |
| Back to top |
back Guest
Posted: Thu Oct 04, 2012 11:18 am Post subject: Re: Super 88 |
yap ! I've been through this before and had good luck with penetrating oil -- let it sit for a few days and start rocking her . But I always remove the vale cover and check for stuck vales by hitting them gently with a hammer or spinning the push rods -- good luck
ps. I have the exact same tractor 1956 super 88 diesel |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
