Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
power steering fluid for 801
Post new topic    Yesterday's Tractors Forum Index -> Ford
Mandomaniac
PostPosted: Tue Oct 02, 2012 3:38 am    Post subject: power steering fluid for 801 Reply to specific post Reply with quote
I have not been able to sort out whether modern power steering fluid would be a good choice for the 'new' power steering assembly I am adding to my 601/801 (has 641 stamped, but 172 motor).
Seems I searched the forum and found one thread that had all kinds of recommendations (including UTF), but now can't find it again.
Why not just modern power steering fluid? It is indeed a 'separate' system from either trans or hydraulics.
Too thin for pump?
Anyway, would appreciate knowing what is 'best' for this old (well....57-59 type) pump.
Thanks.
Will Gumbert
PostPosted: Tue Oct 02, 2012 3:55 am    Post subject: Re: power steering fluid for 801 Reply to specific post Reply with quote
Others here may disagree with me, but I don't see why you couldn't use modern power steering fluid. If you do, consider Valvoline hi-mileage with stop leak. It seems to be nearly as thick as UTF (like M2C134D from CNH) and is essentially hydraulic fluid. It has the advantage that if you have a small leak it can help with that. Prestone makes a similar product. Using UTF is OK too, it has the advantage that you can use one fluid for everything, if that's important to you (it's not to me). -Will
souNdguy
PostPosted: Tue Oct 02, 2012 4:54 am    Post subject: Re: power steering fluid for 801 Reply to specific post Reply with quote
wile it will likely digest anyting from 10w30 to 30w engine oil, atf fluid, ps fluid and straight hyd oil 1so 32/46 I just put utf in mine. one less fluid to stock.
Mandomaniac
PostPosted: Tue Oct 02, 2012 5:26 am    Post subject: Re: power steering fluid for 801 Reply to specific post Reply with quote
Thanks guys,
I have a gallon of power steering fluid and in fact also a quart of the Valvoline High Milage with the 'please don't leak'. Bought a new filter element. Will flush system with some plain PSF then add the Valvoline and top off with plain PSF. Hopefully will do the trick.
old
PostPosted: Tue Oct 02, 2012 7:52 am    Post subject: Re: power steering fluid for 801 Reply to specific post Reply with quote
I have always used ATF in my 841. Tried the UTF once and it did not seem to like the stuff so went back to the ATF.
