Front hitch for H or M
craigreavley
PostPosted: Tue Oct 02, 2012 6:19 am    Post subject: Front hitch for H or M Reply to specific post Reply with quote
Who makes the front hitch for an H or M. I have a homemade one I am borowing. Makes backing a hayrack in the barn a whole lot easier. Is anyone making them? I am talking about a triangular plate with 2 3/4 inch holes that has 2 bolts through it.
Andrew Z
PostPosted: Tue Oct 02, 2012 6:25 am    Post subject: Re: Front hitch for H or M Reply to specific post Reply with quote
why not make your own out of 3/4" plate?
Andrew
DeltaRed
PostPosted: Tue Oct 02, 2012 6:26 am    Post subject: Re: Front hitch for H or M Reply to specific post Reply with quote
Just make your own.pretty easy.If if you dont have the skills or equipment,find someone to make one for you.1/2" plate steel would work,but I would probably use 3/4"....Good luck, Steve
mike1972chev
PostPosted: Tue Oct 02, 2012 6:36 am    Post subject: Re: Front hitch for H or M Reply to specific post Reply with quote
There is also one on EBAY right now.
d beatty
PostPosted: Tue Oct 02, 2012 6:43 am    Post subject: Re: Front hitch for H or M Reply to specific post Reply with quote
The front end hitchs are nice to use. My dad built one for our M in the mid 60's. He cut two pieces of 3/4" plate steel and bolted them to frame. For a cross piece between the two side plates he welded a heavy piece of 4" angle iron with a piece welded in the middle of angle iron with hole to match our drawbar pins. I sold the M a few years ago but took the hitch and put it on my 450.
The Red
PostPosted: Tue Oct 02, 2012 7:44 am    Post subject: Re: Front hitch for H or M Reply to specific post Reply with quote
If I recall correctly, the hole spacing width is slightly different between the H and M.
sflem849
PostPosted: Tue Oct 02, 2012 9:51 am    Post subject: Re: Front hitch for H or M Reply to specific post Reply with quote
I think it is the same as the hitch on the corn pickers.
mkirsch
PostPosted: Tue Oct 02, 2012 12:03 pm    Post subject: Re: Front hitch for H or M Reply to specific post Reply with quote
It's just a piece of steel with three holes in it.
Never had good luck with them, though. Works fine backing straight up but as soon as you turn a little bit the wagon just takes the front of the tractor and shoves it sideways.
Paul from MI
PostPosted: Tue Oct 02, 2012 1:47 pm    Post subject: Re: Front hitch for H or M Reply to specific post Reply with quote
I have one on the 1942 H my grandpa bought new. He was something of a blacksmith and welded steel in his forge. He made this one out of a piece of 3/8 scrap as it has an extra hole on one side and the hole for the drawbar isn't exactly centered. The shape is a bit crude too. It's just one more memory of grandpa for me and it's staying on after I finish restoring the tractor. Never know, I might need to back something up with it!
sflem849
PostPosted: Tue Oct 02, 2012 4:39 pm    Post subject: Re: Front hitch for H or M Reply to specific post Reply with quote
My neighbor bought an M with a big fancy hitch. It used channel from the frame rails and a drop down so you could push harder. They used it to push vegetable wagons in to the cleaner/processer thing.
