Posted: Tue Oct 02, 2012 7:28 am Post subject: The ATV log cart build
Hey guys!!
So, a little while back, I found a cool little trailer on this site made by Gtractorfan, and I decided to make my own version, hopefully to sell when I'm done.
A trip to the city for steel and a few hours later, Its almost ready to go. Its been a really fun project, even if I did screw everything up in the second video, but I'll get that straightened out here sooner or later.
Anyway, I just wanted to share the first two parts of the three part series... Hope everyones enjoying their week, I'll have another video here before too long
video1 video2
Posted: Tue Oct 02, 2012 2:55 pm Post subject: Re: The ATV log cart build
Good neat job. I agree with closing the ends of the tubes. They will collect wasps nests when left open.
You may still have water get in the tubes. When welding tubing closed, the heated air will build up pressure and, on the last weld, will blow a small hole in the melted steel weld. At least that has been my experience when welding galvanized pipe gates. I think you can let the assembly cool and tack weld the hole closed if desired.
Posted: Wed Oct 03, 2012 1:34 am Post subject: Re: The ATV log cart build
I have a hard time with your videos for some reason... Will you post just a normal pic of the finished product please???
Like the others said about closing holes, it's a good idea. However, if it's tuff, Bubba (and me) can be pretty creative.... If one of them open ends has the remote possibility of receiving a slide in (and pin) modification like a saw, meedeater, saw, axe, etc box or mount, leave it open and get you some of the plastic stoppers to plug them....
Posted: Thu Oct 04, 2012 1:53 pm Post subject: Re: The ATV log cart build
Lance,
Just cut the hitch beam flush with the front of trailer and add it to the back. The back of your trailer will become the front and your axle supports will be in the correct position. Seems easier then removing axle supports. Less co-lateral damage
Posted: Fri Oct 05, 2012 10:20 am Post subject: Re: The ATV log cart build
I didn't close the ends of mine and haven't had trouble with varmits, but that would make it more finished. Last fall I moved this buckeye tree and it survived. I had a bunch of weight on the front of the trailer. I made a trench next to the tree and pulled a strong wire under the roots to cut it loose. I have some extrra old Simplicity 2 wheel tractor hubs and wheels, pulling the clip pins lets you remove the wheels in seconds. I underslung the frame to the axle, welded and Ubolted to make it lower and easier to load big pieces.
