| Author |
Message |
rule Guest
Posted: Tue Oct 02, 2012 12:43 pm Post subject: H clutch chatter help |
Can anyone help with H clutch chatter on engage of clutch.Thanks |
| Back to top |
The Red Tractor Guru
Posted: Tue Oct 02, 2012 12:46 pm Post subject: Re: H clutch chatter help |
I had that problem on an F20 several years ago. The culprit was a very worn clutch plate. |
| Back to top |
Janicholson Tractor Guru
Joined: 30 Jan 2004 Posts: 18229 Location: St. Cloud, MN
Posted: Tue Oct 02, 2012 12:49 pm Post subject: Re: H clutch chatter help |
Glazing can be the issue, but it is usual to replace the disk and PP as well as the Bearings to make it stop. Can be done through the bottom W/O split. Jim |
| Back to top |
ruel Guest
Posted: Tue Oct 02, 2012 12:50 pm Post subject: Re: H clutch chatter help |
New pressure plate ,clutch disc ,resurfaced flywheel. Thinking some adj. i dont know about maybe.Thanks |
| Back to top |
CNKS Tractor Guru
Posted: Tue Oct 02, 2012 1:37 pm Post subject: Re: H clutch chatter help |
Disc could be in backwards--the curved part has to face the rear. |
| Back to top |
rhtx55 Long Time User
Joined: 15 Apr 2011 Posts: 631 Location: Republic of Texas
Posted: Tue Oct 02, 2012 3:53 pm Post subject: Re: H clutch chatter help |
Clutch needs to be " burnished" (broken in).
Put it in high gear & hold the brakes, slowly let out on the clutch until the engine rpm drops, hold a second or two & release. Two to three times & this should take the "grabbiness" out of it.
New clutches tend to be grabby until they are broken in, or used for heavy field work. |
| Back to top |
Posted: Tue Oct 02, 2012 4:09 pm Post subject: Re: H clutch chatter help |
The reality is that it will take a week or two of use for it to mellow into smooth operation. The finish on the FW and pressure plate will be non directional, and (the surface of the friction disk, rough. They don't have much cushion, and therefore are a bit sensitive. If it is a ceramic puck style clutch, that may be all you get, they are often like switches. Jim |
| Back to top |
c1802362 Regular
Posted: Tue Oct 02, 2012 5:25 pm Post subject: Re: H clutch chatter help |
I had the same problem a while back - the issue was the ball bearing on the clutch pilot had worn out and wasn't centering the shaft |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
