| Author |
Message |
showdown Regular
Posted: Tue Oct 02, 2012 5:16 pm Post subject: gas Oliver 77 vers. deseil 77 weight of tractor |
Does a deseil 77 weigh more than a gas?, mine is a 54.Thanks.......... |
| Back to top |
Bouncer Tractor Guru
Posted: Tue Oct 02, 2012 6:25 pm Post subject: Re: gas Oliver 77 vers. deseil 77 weight of tractor |
Copied this from Tractor Data.
Weight (operating):
4,207 lbs [1908 kg] (gas)
4,502 lbs [2042 kg] (diesel)
Tractor Data
| Back to top |
buickanddeere Tractor Guru
Joined: 31 May 2003 Posts: 23636 Location: in front of computer
Posted: Wed Oct 03, 2012 1:03 pm Post subject: Re: gas Oliver 77 vers. deseil 77 weight of tractor |
"Diesel" not "deseil" |
| Back to top |
LarryM Regular
Posted: Wed Oct 03, 2012 5:20 pm Post subject: Re: gas Oliver 77 vers. deseil 77 weight of tractor |
Really? You corrected what is obviously someone's typo? Says a lot about a person.  |
| Back to top |
chucksoliver77 Long Time User
Posted: Wed Oct 03, 2012 7:22 pm Post subject: Re: gas Oliver 77 vers. deseil 77 weight of tractor |
showdown, i don't know if tractor data has it right, the only differences are the injector pump, timing cover, injector pump drive gears, injectors. fuel lines, transfer pump and fuel filters. take away the carb. coil, and distributor and i see maybe 30-50 lbs. extra weight. just my 2 cents, chuck i forgot that the starter is bigger and i think the bell housing is a little different, the head is different and the ring gear is a bit bigger, maybe making the Diesel about a 100lbs. heaver.
Last edited by chucksoliver77 on Thu Oct 04, 2012 2:51 am; edited 1 time in total |
| Back to top |
Posted: Wed Oct 03, 2012 7:33 pm Post subject: Re: gas Oliver 77 vers. deseil 77 weight of tractor |
There are typos and then there is not having a clue how to spell. The real sin however is being too lazy to perform a spell check. |
| Back to top |
showdown Regular
Posted: Thu Oct 04, 2012 12:08 pm Post subject: Re: gas Oliver 77 vers. deseil 77 weight of tractor |
Hey Chuck: I Looked at the tractor data, I think that that 300 ibs. ia a little off the mark too. I guess you are much closer, it looks like the diff. is in the engine department from other info i could find. Thanks for your help. PS I guess theres no type Os Ha. Ha. LOL.... |
| Back to top |
Posted: Thu Oct 04, 2012 12:54 pm Post subject: Re: gas Oliver 77 vers. deseil 77 weight of tractor |
| showdown wrote: | | (quoted from post at 01:08:34 10/05/12) Hey Chuck: I Looked at the tractor data, I think that that 300 ibs. ia a little off the mark too. I guess you are much closer, it looks like the diff. is in the engine department from other info i could find. Thanks for your help. PS I guess theres no type Os Ha. Ha. LOL.... | youre walcome. chucck |
| Back to top |
mm585 Regular
Posted: Fri Oct 05, 2012 2:40 pm Post subject: Re: gas Oliver 77 vers. deseil 77 weight of tractor |
This isnt a spelling bee!! I doubt ther is less than 100 pounds diff. between a gas and a diesel. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
