Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
IH 460 stuck between gears
Larry Koski
PostPosted: Tue Oct 02, 2012 6:53 pm    Post subject: IH 460 stuck between gears Reply to specific post Reply with quote
My IH 460 utility is stuck between two gears. I removed the shifter an noticed that the end of the shifter is badly worn. When sitting on the seat, I can see that the 3 channels that should be aligned when in neutral, are positioned as follows: the channel on the left moves freely, the one in the center is stuck about 1/2" back from the neutral position, and the one on the right is stuck about 1/2" forward of the neutral channel. I have tried to pry them so that they will align with each other but they won"t move. Any suggestions as to how I can get them to line up? How much pressure is safe to apply when trying to pry them to where they have to be for neutral.
Hugh McKinney
PostPosted: Tue Oct 02, 2012 6:59 pm    Post subject: Re: IH 460 stuck between gears Reply to specific post Reply with quote
You're on the right track, but you'll need to jack up one of your rear wheels so that it will rotate freely. Be sure to block your front wheels, fore and aft, for safety. Also, depress your clutch pedal a time or two. You shouldn't have to apply much pressure to align the shifting rails...the problem, I'm guessing, is that it's either on an incline or your clutch pedal needs depressing to relieve the pressure. It happens occasionally on my 450. Good luck.
LaDuke Farmall
I got one that will do that. try to rock the tractor then put your bar in there to pop it back. somtimes you need to have someone apply pressure when the tractor is getting rocked.
DeltaRed
PostPosted: Tue Oct 02, 2012 7:00 pm    Post subject: Re: IH 460 stuck between gears Reply to specific post Reply with quote
Jack up a rear wheel.That should take the pressure off the gears.You can apply quite a bit of pressure...If that doesn't work,you may have to pull the top.
Janicholson
PostPosted: Tue Oct 02, 2012 7:59 pm    Post subject: Re: IH 460 stuck between gears Reply to specific post Reply with quote
Pull the TA back as well, this releases the sprague /ramp/rollers. Jim
Larry Koski
PostPosted: Wed Oct 03, 2012 2:03 am    Post subject: Re: IH 460 stuck between gears Reply to specific post Reply with quote
As a matter of fact, the tractor is on a slight uphill grade as it sets there. I'm going to try all the suggestions that I have received from you folks and I'll get back with the results.
mkirsch
PostPosted: Wed Oct 03, 2012 4:26 am    Post subject: Re: IH 460 stuck between gears Reply to specific post Reply with quote
Yup, it's bound up because the weight of the tractor is against the gears.
You may need to get another tractor, hook on with a chain, and put some tension on the chain to relieve the pressure.
Duane966
PostPosted: Wed Oct 03, 2012 12:55 pm    Post subject: Re: IH 460 stuck between gears Reply to specific post Reply with quote
when our 560 gets stuck like that we take the gear shift off and use a big screw driver or pry bar and realign the rails. works great!
hth
Duane
Duane966
PostPosted: Wed Oct 03, 2012 1:00 pm    Post subject: Re: IH 460 stuck between gears Reply to specific post Reply with quote
sorry, misread your post. you will need to jack the wheel or use a big hammer. btdh!
Larry Koski
PostPosted: Thu Oct 04, 2012 10:26 am    Post subject: Re: IH 460 stuck between gears Reply to specific post Reply with quote
Well, I tried prying, rocking, and jacking the tractor to get those shift rails to align but no luck. Finally decided that if I pry too hard on those somewhat worn parts, they will break and I'll have to remove the top. So I'm in the process of removing the top. I would suppose that I'd better remove those ball bearings below the shifter springs before I remove the top or they'll fall inside. Although I was really hoping to avoid removing the top, there are some other repairs that I can do while I have the tractor apart...looking for that silver lining.
Larry Koski
PostPosted: Mon Oct 15, 2012 3:40 pm    Post subject: Re: IH 460 stuck between gears Reply to specific post Reply with quote
Thanks to all the forum members that lended their knowledge so that I could get my 460 gears unstuck. I tried all the suggestions but what finally worked for me was removing the top of the transmission and using a 1"x4"x2' board with one end placed near the center of the gear and then striking the other end with a large hammer. It took about 3 good blows before it released. Thanks again, you folks are the best!!!
