| Author |
Message |
tn8n Regular
Joined: 23 Oct 2011 Posts: 114 Location: Knoxville, TN
Posted: Wed Oct 03, 2012 5:03 am Post subject: crankshaft oil seals |
do i need to cut off the rope seals not quite flush, but a little proud, maybe 1/8"? new out of the package they stick up probably 1/4" so when i lay the oil pan on, it lays up off the bottom of the block a good ways. i don't want to rely on cranking the oil pan bolts down to pull it together.
also, as for a clutch alignment tool, is it best to just remove the trans input shaft and use it? |
| Back to top |
HCooke Tractor Expert
Posted: Wed Oct 03, 2012 5:15 am Post subject: Re: crankshaft oil seals |
"also, as for a clutch alignment tool, is it best to just remove the trans input shaft and use it?"
Yes, and replace the seal in it while you have it out.
As far as the seal, maybe 1/16" proud. |
| Back to top |
tn8n Regular
Posted: Wed Oct 03, 2012 5:54 am Post subject: Re: crankshaft oil seals |
is this the seal?
i couldn't find anything on this site.
oil seal main drive gear bearing
| Back to top |
souNdguy Tractor Guru
Posted: Wed Oct 03, 2012 7:05 am Post subject: Re: crankshaft oil seals |
7052a yep.. that's it.. it's listed right here on this site....
ytmag 8n / drivetrain parts
| Back to top |
POPGUN Regular
Posted: Wed Oct 03, 2012 10:47 am Post subject: Re: crankshaft oil seals |
Yes on cut off proud. The best advice I ever got on the rope is to use the gray silicone on the ends and offset the seams of the block and rope about 20 degrees. Works great and lessens chance of a leak. |
| Back to top |
Russel AZ Regular
Posted: Wed Oct 03, 2012 3:56 pm Post subject: Re: crankshaft oil seals |
do not cut the rope seals off.
Use something about the same round and using a hammer tap them down into the holders. They fit and the pan will pull down just fine. |
| Back to top |
36 Coupe Tractor Guru
Posted: Sun Oct 14, 2012 2:06 am Post subject: Re: crankshaft oil seals |
Rope seals should be soaked in oil befor using.I used to keep some in a jar of oil.Never cut the ends.I have a clutch alignment tool but use the input shaft from a Ford car transmission on most jobs. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
