| Author |
Message |
MFan Regular
Posted: Wed Oct 03, 2012 5:05 am Post subject: Anyone added a panel to make garage door taller? |
Just wondering if it would work to add a panel to a garage door to get more height. For example, I have a 9w x 7h garage door (4 21" panels). Can I add an additional 21" panel to make a taller door? Anyone ever done this with success? I have extra track etc. and the headroom above for a taller door. |
| Back to top |
Inno Tractor Expert
Joined: 11 Nov 2009 Posts: 1874 Location: NW Ontario Canada, Near Beautiful Rainy Lake
Posted: Wed Oct 03, 2012 5:08 am Post subject: Re: Anyone added a panel to make garage door taller? |
The only thing I can think that might be a problem is not enough spring tension for the heavier door. You might have to upgrade your springs too. Other than that I can't see why it wouldn't work, aside from making your opening bigger and framing it properly etc.
| Back to top |
Ken Macfarlane Tractor Expert
Posted: Wed Oct 03, 2012 5:10 am Post subject: Re: Anyone added a panel to make garage door taller? |
Yes, its easy to do. Its how the commercial door guys work around here. They stock panels and track kits and stack em to the side you need.
The brackets for the panel will have to have the right standoff for the taper of the track so the new panel lays flat, but those are available at over head door places or from installers. |
| Back to top |
batractorman Regular
Posted: Wed Oct 03, 2012 5:11 am Post subject: Re: Anyone added a panel to make garage door taller? |
You might wanna check with a garage door guy to make sure the spring doesn't need to be made to allow for that much travel. May need to be longer or different tension on torsion type.
Heard about adding panels, must be possible. |
| Back to top |
MFan Regular
Posted: Wed Oct 03, 2012 5:27 am Post subject: Re: Anyone added a panel to make garage door taller? |
Thanks for the quick replies. Good poing about the spring issue, I will check into that. This is for new construction (that hasn't taken place yet) so the door opening can be whatever it needs to be. I just want the door lined up before I start building. |
| Back to top |
Chip812 Long Time User
Posted: Wed Oct 03, 2012 7:36 am Post subject: Re: Anyone added a panel to make garage door taller? |
You'll also need to add more track... |
| Back to top |
Dave Sherburne NY Tractor Expert
Posted: Wed Oct 03, 2012 9:14 am Post subject: Re: Anyone added a panel to make garage door taller? |
It can certainly be done You need new, panel new brackets for more standoff on the top panel, different track and new springs. If you want a bigger door it might be more cost effective to find a bigger one and use the smaller one in an other spot. I'm lucky enough to have a fellow less than a mile up the road who makes doors and has everything in stock. I once asked him if after buying 10 doors do I get one free. He said it used to be that way but I have to buy 11 now. |
| Back to top |
LenND Tractor Expert
Posted: Wed Oct 03, 2012 11:03 am Post subject: Re: Anyone added a panel to make garage door taller? |
I added to my 16 foot. I added the extra length of the track to the bottom. That way you can get by with a straight piece of track cause the distance between door and track can be same as bottom of original track. You will need to add more springs or heavier ones. |
| Back to top |
Posted: Wed Oct 03, 2012 11:08 am Post subject: Re: Anyone added a panel to make garage door taller? |
Forgot some info. You should add you new extension to the bottom also to keep the spacing for the rollers right. I raised the whole track up the 21 or so inches. |
| Back to top |
oliver power Regular
Posted: Wed Oct 03, 2012 4:38 pm Post subject: Re: Anyone added a panel to make garage door taller? |
Yes, just about every overhead door installer. They start with the bottom panel, and work thier way up. Every panel added makes the door taller. This reply isn't ment to be a smart a$$ reply. It's ment for you to look at how they are installed in the first place. As others have said, extend the bottom of the track, not the top. |
| Back to top |
Russ from MN Tractor Expert
Posted: Thu Oct 04, 2012 8:54 am Post subject: Re: Anyone added a panel to make garage door taller? |
I have done that, works OK but you need different springs. They recommend setting the compete door on a scales with no springs connected and then measure the travel and they can provide the right spring. |
| Back to top |
Bill in Colo Long Time User
Joined: 01 Oct 1999 Posts: 923 Location: Rio Blanco,county Colorado
Posted: Wed Oct 10, 2012 6:46 pm Post subject: Re: Anyone added a panel to make garage door taller? |
Nephew just add two panels to a 16 wide door so he could get his backhoe and rv inside.cost was about 2000 including a new opener Wayne Dalton doors. |
| Back to top |
Pops1532 Regular
Posted: Thu Oct 11, 2012 3:47 am Post subject: Re: Anyone added a panel to make garage door taller? |
Lots of good info so far.
Depending on the brand of door you might have to remove the top panel, set your new panel, then put the top one back on.
I'd suggest new tracks rather than extending your tracks. The door will operate more smoothly.
By the time you buy a panel, tracks, springs, cables, and hinges, you'd probably be money ahead to buy a new door. Keep in mind if you ever need to replace the door you'll have to go through all of this again.
If you're planning on having an electric opener you'll have to get one for a taller door.
If you decide to go new I recommend Raynor doors. I've installed many brands and Raynor has the best doors I've used by far. |
| Back to top |
