Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
TO-30 Hyd pumps
Post new topic    Yesterday's Tractors Forum Index -> Harry Ferguson
John Dunlap
PostPosted: Wed Oct 03, 2012 7:19 am    Post subject: TO-30 Hyd pumps Reply to specific post Reply with quote
How do I remove the Hyd pumps from this machine. Do I have to remove the drive shaft that turns pinion gear or does a panel on the bottom have to be removed.
Jeff-oh
PostPosted: Wed Oct 03, 2012 7:34 am    Post subject: Re: TO-30 Hyd pumps Reply to specific post Reply with quote
THese are easy to remove if necessary.
Steps.
1) Drain fluid from middle and aft plugs. Drain some down from front plug. Oil can be saved and re-used if in good shape (no water)
2) Remove the side cover plates.
3) Disconnect one side of the control fork support. ("U" shaped bracket between the forks over the PTO shaft.)
4) Disconnect the control fork from the control valve yoke. (This can be done by hand by spreading the fork arms and disconnecting one side then the other)
5) Remove the PTO shaft. (remove 4 cap bolts and pull shaft aft and out.
6) Remove the Pump flange bols (10 bolts on underside of tractor
7) Slide pump aft 1/8" and remove out the bottom of the tractor. (Note the gasket may stick the flanges together and light prying may be required.)
Reverse for assembly
Jeff
Richard L
PostPosted: Wed Oct 03, 2012 2:47 pm    Post subject: Re: TO-30 Hyd pumps Reply to specific post Reply with quote
Good luck with your thinking, usually when I think like that everyone goes to the auction cause they can't work in the fields.
Richard L
PostPosted: Wed Oct 03, 2012 2:48 pm    Post subject: Re: TO-30 Hyd pumps Reply to specific post Reply with quote
sorry posted on the wrong slot.
