| Author |
Message |
6t6cuda Regular
Posted: Wed Oct 03, 2012 8:38 am Post subject: Position control not working |
On my ford 641, the position / draft control knob does not stay up, I think it is operating in draft control only.
Is there an adjustment to set this?
The hydraulics work fine and respond fine otherwise. |
| Back to top |
JMOR Tractor Guru
Posted: Wed Oct 03, 2012 8:43 am Post subject: Re: Position control not working |
| 6t6cuda wrote: | (quoted from post at 12:38:21 10/03/12) On my ford 641, the position / draft control knob does not stay up, I think it is operating in draft control only.
The hydraulics work fine and respond fine otherwise. | "Rexaxed" or default position should be Position control, i.e., against spring force when moving the lever should be Draft control. A mechanical latch, so I don't see an 'adjustment'. Maybe lever has slipped on shaft? |
| Back to top |
souNdguy Tractor Guru
Posted: Wed Oct 03, 2012 9:36 am Post subject: Re: Position control not working |
post a pic..
this is a lever.. not a knob... |
| Back to top |
awhtx Tractor Guru
Joined: 16 Jan 2002 Posts: 5048 Location: Lampasas, TX
Posted: Wed Oct 03, 2012 9:41 am Post subject: Re: Position control not working |
There are two detents machined into the shaft that the Position/Draft control lever is attached to. A spring loaded ball drops into each detent holding the lever in the desired position as it is changed from Position to Draft or vice versa. |
| Back to top |
ZANE Tractor Guru
Posted: Sun Oct 07, 2012 5:42 pm Post subject: Re: Position control not working |
You will have to go into the lift housing to see what is up. Could be one of the small pins that hold the latch together that changed between draft and position. Or could be the cam follower pin is lost or worn completely through etc.
Zane |
| Back to top |
6t6cuda Regular
Posted: Thu Oct 11, 2012 5:25 pm Post subject: Re: Position control not working |
| 6t6cuda wrote: | (quoted from post at 13:38:21 10/03/12) On my ford 641, the position / draft control knob does not stay up, I think it is operating in draft control only.
sorry, it has been a while and a lot of "other" stuff going on (trying to build a garage).
Yes it is a lever not a knob...
It does hold two positions but they are about 30 degrees apart, one is parallel to the lift plate and the other one is about 30 degrees up. both positions appear to do the same thing when lifting an implement. From the manual it appears that they should be at a right angle for the two positions.
Is there a good test to tell if it is in draft vs. position when just lifting an implement? - I understand when plowing it will act different
Still learning a lot! |
| Back to top |
JMOR Tractor Guru
Posted: Thu Oct 11, 2012 7:02 pm Post subject: Re: Position control not working |
| 6t6cuda wrote: | (quoted from post at 21:25:24 10/11/12) | 6t6cuda wrote: | (quoted from post at 13:38:21 10/03/12) On my ford 641, the position / draft control knob does not stay up, I think it is operating in draft control only.
Still learning a lot! | Yes. In Draft, the touch control lever will be almost "digital', i.e., on/off or it will lift or drop, whereas in Position control it will act more linear, i.e., raise the lever a little, the lift will raise a little, lower the lever a little , the lift will lower a little. It will not be all or nothing but more proportional. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
