| Author |
Message |
Mr Farmall Guest
Posted: Wed Oct 03, 2012 1:27 pm Post subject: Blown head gasket on A |
Four years back my A started to pump out white smoke, sure enough it was a bad head gasket. Found antifreeze in the crankcase. Replaced the head gasket with an IH/Case gasket. Cleaned off the deck and head real well. I used Permatex copper spray a gasket on the new head gasket, torqued the head to 65 ft/Lb like the repair manual states.
Now the A has started smoking white really bad again, I can't find antifreeze in the oil and the compression checks out okay. It has never overheated as long as I have owned it, don't know if it ever did before I bought it.
Any suggestions to ensure that the next head gasket last longer? Should I have the head checked and milled if needed? |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50473 Location: Lake of the Ozarks area of MO
Posted: Wed Oct 03, 2012 1:36 pm Post subject: Re: Blown head gasket on A |
The new torque for that is 85ft/lbs so that in it self may help. When I built my BA I used a used head gasket metal one and 6 colts of aluminum paint and it has been just fine. I too did use the 65ft/lbs but since it has not leaked I have left it alone but did re-torque it after I had warmed the engine up |
| Back to top |
ken house Regular
Posted: Wed Oct 03, 2012 2:22 pm Post subject: Re: Blown head gasket on A |
without a doubt, have head checked. it is your machine and not mine, but, i believe that i would run the motor, get it warm and torque the bolts up to the new specification. |
| Back to top |
Mr Farmall Guest
Posted: Wed Oct 03, 2012 3:05 pm Post subject: Re: Blown head gasket on A |
I have tried tighting it up to 85 torque, it didn't help. Still smokes white really bad. |
| Back to top |
Charlie M Long Time User
Posted: Wed Oct 03, 2012 3:58 pm Post subject: Re: Blown head gasket on A |
Maybe a cracked sleeve? When I bought my A last fall the previous owner had to replace 2 sleeves because they were cracked. They are wet sleeves. |
| Back to top |
old Tractor Guru
Posted: Wed Oct 03, 2012 4:05 pm Post subject: Re: Blown head gasket on A |
Yep either you blew the head gasket again which happens or you may have a cracked head which would be bad |
| Back to top |
gene bender Tractor Guru
Posted: Wed Oct 03, 2012 4:42 pm Post subject: Re: Blown head gasket on A |
Head should be 80lbs and your smoke could be coming from residue in the muffler running it under some load should burn it out but i would retourque the head. |
| Back to top |
Mr Farmall Guest
Posted: Wed Oct 03, 2012 9:43 pm Post subject: Re: Blown head gasket on A |
Just found an online article that says copper spray a gasket attacks the coating on metal head gaskets. That is probably what happrned with my A. I will have the head milled just to be sure. |
| Back to top |
old Tractor Guru
Posted: Thu Oct 04, 2012 6:46 am Post subject: Re: Blown head gasket on A |
Also when you put it back on use a coat of aluminum paint on both sides of the gasket install that tacky. Torque the head down wait say an hour then start and after warm re-torque the head |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
