| Author |
Message |
boberjagel Guest
Posted: Wed Oct 03, 2012 2:36 pm Post subject: soybean losses |
hey guys how many soybeans per square foot equals a bushel. we have losses so bad the ground is yellow on what was already only a 20 bushel year |
| Back to top |
oldtanker Tractor Guru
Posted: Wed Oct 03, 2012 2:39 pm Post subject: Re: soybean losses |
| boberjagel wrote: | | (quoted from post at 15:36:51 10/03/12) hey guys how many soybeans per square foot equals a bushel. we have losses so bad the ground is yellow on what was already only a 20 bushel year |
Don't know but I do know that the guys here were moving very slow while combining beans. The faster they tried to go the more were on the ground.
Rick |
| Back to top |
leej Regular
Posted: Wed Oct 03, 2012 3:23 pm Post subject: Re: soybean losses |
Are the beans coming off at the cycle bar? Or are the coming from the rear of the combine?
Off the cycle bar, could be dull blades or you
are going to fast or there is slippage at the
cutter bar. From the rear to fast fan, or baffle
is broke or not set correctly,sieve not set properly.Probably other thing that were not mentioned. ggp |
| Back to top |
Janicholson Tractor Guru
Joined: 30 Jan 2004 Posts: 18454 Location: St. Cloud, MN
Posted: Wed Oct 03, 2012 3:34 pm Post subject: Re: soybean losses |
The following info seems comprehensive. Page 139 is relevant. Jim
The answer
| Back to top |
Mark-Ia Long Time User
Posted: Wed Oct 03, 2012 4:15 pm Post subject: Re: soybean losses |
A lot of beans are on the ground due to the pods splitting open. They are dry, only 8% moisture, or less. |
| Back to top |
c.hess Regular
Posted: Wed Oct 03, 2012 4:39 pm Post subject: Re: soybean losses |
North Dakota ext says 4small beans per sq foot =i bu per acre.Large beans 3 =i bu per acre. Say 30 foot head = 30 sq feet.So 90 beans found in full width = i bu loss per acre. |
| Back to top |
JWalker Regular
Posted: Wed Oct 03, 2012 4:41 pm Post subject: Re: soybean losses |
cut them late at night, after the dew has fallen or early in the morning before dew dries. Not a perfect solution and will not work if you have hundreds of acers to cut but it will help if the moisture is that low. |
| Back to top |
fixerupper Tractor Guru
Joined: 12 Oct 2003 Posts: 7046 Location: Albert City Iowa
Posted: Wed Oct 03, 2012 6:19 pm Post subject: Re: soybean losses |
3 beans/sq ft.= 1 bushel. We've had some 'dry pop' where the pods just gave up and popped open when they got down to 7%. A little hail didn't help matters.Jim |
| Back to top |
USAonly Guest
Posted: Wed Oct 03, 2012 6:41 pm Post subject: Re: soybean losses |
Some people brag how fast they can go cutting beans---BULL SH%T!! We have a JD 8820-A good old-in its day-big combine.We had a 222 head on it years ago and everybody said to put a Tiger Jaw sickle on it- you can cut at 5 mph-Not true. I traded for a 925 JD platform-best thing I ever did-I cut at 3.5 mph I have the course sections and it does a GREAT job! When beans are 8% you will see shatter! GOOD LUCK!!!! |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
