Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
CASE LA experts
Post new topic    Yesterday's Tractors Forum Index -> Case and David Brown
GConn
PostPosted: Wed Oct 03, 2012 5:16 pm    Post subject: CASE LA experts Reply to specific post Reply with quote
I purchased a LA case at a estate sale some years ago , after I got it home, running, and cleaned up, it turned out to be a nice tractor . but in the process of cleaning I found that the rear end under the bull gears had cracked and been sorta repaired/welded. someone said it was because the chains had got lose and jumped a tooth ? Recently I purchase another parts tractor unseen at scrap iron price for the rear to switch ,IT"S CRACKED TOO! Looks like maybe water froze and busted it , how common is this??? hard to tell sometimes till you realy clean it up .
chuck machinist
PostPosted: Wed Oct 03, 2012 6:43 pm    Post subject: Re: CASE LA experts Reply to specific post Reply with quote
I cannot speak for others on this subject ,but it has been my experience,that moisture settling in the bowels of any piece of equipment can be devastating.The good news is that it sounds as if you have the makings of a great parts tractor at scrap price or possibly two good LA's Keep us updated on your progress ! Good Luck ! Chuck It pays to look closely!
casecollectorsc
PostPosted: Wed Oct 03, 2012 7:09 pm    Post subject: Re: CASE LA experts Reply to specific post Reply with quote
Got a 930 Western that had the floor of the case cracked because a chain broke. Cleaned the inside floor up and put about 3 tubes of JB on it and let dry a couple days before putting together. I know it won't weld it, but it did keep it from leaking. The case is too thick to get enough heat to weld it.Still holden 5 years later!
1031D
PostPosted: Wed Oct 03, 2012 8:21 pm    Post subject: Re: CASE LA experts Reply to specific post Reply with quote
A lot of times what happens is guys break a chain, don't have a clue there's even chains in there and hook a chain on it and pull it home, only to have the bull sprocket blast the chain out the bottom in 50'. Watched a guy at plow days do it a couple years back with a 500.
Ken in AZ
PostPosted: Thu Oct 04, 2012 5:59 am    Post subject: Re: CASE LA experts Reply to specific post Reply with quote
This happens on the D series too. My DH had this happen and someone painstakingly rewelded the case. While it seeps a little oil, it's been holding together for around 50 years that I can vouch for. My Dad learned to weld from the gentleman that did the welds on the tractor. They CAN be repaired but it takes time, skill and patience.
One minor thing I wish they'd done after the repair is to coat the inside of the case with glytol or some other sealant again. The case is actually seeping oil through the casting as best I can tell. Great work though, and way beyond what I'm capable of.
Ken in AZ
GConn
PostPosted: Thu Oct 04, 2012 5:46 pm    Post subject: Re: CASE LA experts Reply to specific post Reply with quote
Thanks for the imput guys, looks like the best thing to do is the coating JB weld on the inside of mine(till I run accrosst a rear that I am sure not cracked) The parts tractor has no sheet metal or wheels ,block is cracked, but dose have a pto that mine is lacking and was able to salvage a eagle mag core, pto and a head.I will probably take to scrap as soon as time premits to recover my investment and keeping the place cleaned up. If someone else needs to pick the bones let me know( located south/ central Ohio)
1031D
PostPosted: Thu Oct 04, 2012 6:43 pm    Post subject: Re: CASE LA experts Reply to specific post Reply with quote
Why don't you put up a couple pictures im case anybody needs anything they can see what you all have. I'm looking for radiator sides and a bottom tank but moneys a little tight right now.
GConn
PostPosted: Fri Oct 05, 2012 8:37 am    Post subject: Re: CASE LA experts Reply to specific post Reply with quote
1031, I took a look ,the sides look OK but the bottom is cracked like every thing else. At 10 cents a pound not much, dissambling radiator and shippng ??? What do you need? are you close to me??let me know. Pictures , I would have to get my kids to do that!
1031D
PostPosted: Fri Oct 05, 2012 6:28 pm    Post subject: Re: CASE LA experts Reply to specific post Reply with quote
Mine only has one good grill mounting screw ear, other 3 broke off. My bottom tank has pin holes in it, may just take off and weld up as pepper won't stop it. Mine leaks about 5 gallons a week and in the summer it's no biggie to top it off. The top tank alone holds 5 gallons!!!!!! Moose!
