Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
670 Diesel miss
Post new topic    Yesterday's Tractors Forum Index -> Minneapolis Moline
Joe Pro
PostPosted: Wed Oct 03, 2012 7:42 pm    Post subject: 670 Diesel miss Reply to specific post Reply with quote
My 670 super diesel has never ran quite right. It runs decent at higher rpm's but has varrying speed at lower rps's. I have replaced the filters many times and put a pickup tube in the fuel tank. I have bleed the system many times also. When I first start it, it surges a bit. It seems that number one and two cylinders are colder to the touch than the back two.
When bleeding the injectors, when I crack number 4 at an idle the engine will die and it will not when the fromt three are cracked. I'm not sure if it is an energy cell issue, injector issue or pump issue? I'm not new to this just don't want to over think it. It seems to surge a bit more than miss but also runs rough at slower speeds, I can watch the tac bounce under 1000 rpm's.
Dieseltech
PostPosted: Thu Oct 04, 2012 5:49 am    Post subject: Re: 670 Diesel miss Reply to specific post Reply with quote
You may have injection pump trouble, weight retainer ring may be breaking up inside causing erratic governor control. Just fixed an M-602 pump that had the same problem with surging. If not repaired and retainer pins break off it will take out the head assembly and break the drive shaft, a LOT more costly to fix.
Heath72
PostPosted: Thu Oct 04, 2012 2:51 pm    Post subject: Re: 670 Diesel miss Reply to specific post Reply with quote
Had the same problem with a 4020 once. It fluttered alot between 1000 and 1200 RPM's, but ran fine at higher speed. They went through the pump, and the problem was the retainer ring went bad. It ran like a new one $600 later!
mikey h.
PostPosted: Thu Oct 04, 2012 4:33 pm    Post subject: Re: 670 Diesel miss Reply to specific post Reply with quote
you may very well have retainer ring problems in the pump with erratic governor action at idle speed, but do not over look the injector tips they open relativly low around 1850 p.s.i. with a solid core and atomization coning out from the tip for proper pre cup operation.
Post new topic    Yesterday's Tractors Forum Index -> Minneapolis Moline All times are GMT - 8 Hours
