| Author |
Message |
LARRY CAIN New User
Posted: Thu Oct 04, 2012 8:11 am Post subject: STARTING MY 8N AFTER 2 YRS. |
BOUGHT A 1950 8N THAT HAS SIT FOR 2 YRS. OWNER
SAYS IT RAN WHEN HE PARKED IT. WHAT SHOULD I DO
TO IT BEFOR TRYING TO START IT? |
| Back to top |
Andy C Regular
Posted: Thu Oct 04, 2012 1:57 pm Post subject: Re: STARTING MY 8N AFTER 2 YRS. |
Heck! Check the oil and coolant and put a gallon of gas in it. Then put a battery in it or tow it off and see what happens! Pretty good chance it will start.
Good Luck and let us know,
Andy |
| Back to top |
GlenIdaho Tractor Expert
Posted: Thu Oct 04, 2012 2:23 pm Post subject: Re: STARTING MY 8N AFTER 2 YRS. |
I would go a little farther by checking the air filter for debris and/or nests, clean and re-oil; pull the plugs and put a cup of atf mixed with diesel in each cylinder and let it sit for a day or two to loosen and lube the rings; then remove fluid (may have to pump it out by cranking engine); at the same time look for any water in the cylinders; while you're at it do a compression test; check radiator for any obstructions; check trans, etc for water, if found drain and replace. Check engine oil for water/anti-freeze and replace oil and filter; Check each plug, clean and regap; check all electrical connection to make sure bright and tight. That should get you going. |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50428 Location: Lake of the Ozarks area of MO
Posted: Thu Oct 04, 2012 2:25 pm Post subject: Re: STARTING MY 8N AFTER 2 YRS. |
#1 loose the cap lock people do not like to be yelled at. #2 put say a 1/4 cup of ATF in each cylinder and let it sit over night that way. #3 clean the points or replace the points. #4 pour some gas in the tank and pull the carb drain plug and let some gas flow out of the drain plug hole. Catch it to use it and make sure it is not full of rust from sitting so long. Then give it a go and it may just run |
| Back to top |
BDT in Minnesota Long Time User
Joined: 25 Feb 2006 Posts: 1048 Location: Erskine, Mn
Posted: Sun Oct 07, 2012 8:00 am Post subject: Re: STARTING MY 8N AFTER 2 YRS. |
Two years is not that long.... check All the fluid levels, drain the carb and clean the sediment bowel if needed, check the air cleaner, and battery condition.. ... Try staring it.. Bring a can of fresh gasoline along, |
| Back to top |
Phil9N3667 Regular
Posted: Sun Oct 07, 2012 5:18 pm Post subject: Re: STARTING MY 8N AFTER 2 YRS. |
Larry, if you want really good advice on this besides the other good previous replies, go to the 9N/2N/8N board! You can also download BruceVa's 50 tips to help you out. |
| Back to top |
Randy Roberson Regular
Posted: Wed Oct 24, 2012 12:07 pm Post subject: Re: STARTING MY 8N AFTER 2 YRS. |
Started one just like it a few months ago. Engine was free, cleaned out the gas tank, carb (carb has to be clean or it won't run right, ask me how many times I took this one apart)put in a battery, points and plugs, and busted her off. She ran very nicely, too, they are sweet, gentle machines when they are halfway right.
Engine stuck: try oil in the cylinders (usually only one cylinder is the problem) and try rocking or moving the crank with a wrench or bar. Get too rough and maybe break a ring. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
