| Author |
Message |
jerry 4 Guest
Posted: Thu Oct 04, 2012 8:50 am Post subject: water in crank case |
i have a older riding mower witch sat out the most of its life. the engine oil is milky white,and ihave have changed it a number of times trying to clean it up.i was wondering if a little bit of isopyrple dry gas would hurt anything? and would this hurt any thing? i dont know if its condensation. |
| Back to top |
jerry4 Guest
Posted: Thu Oct 04, 2012 9:01 am Post subject: Re: water in crank case |
i wanted to add this is just a beater tractor i use for firewood and the kids play on [poor mans 4wheeler]i am running HD30 oil |
| Back to top |
rrobert Regular
Posted: Thu Oct 04, 2012 10:31 am Post subject: Does it have an oil filter? |
Two oil changes should have gotten most of the water out unless there was water in the filter. The rest of the water should evaporate with use. I will usually let them warm up a few minutes and then drain the oil.
I have heard water in oil will ruin car engine bearings.
If the case is sealed, then it is probably condensation. If the dipstick is missing, then oil would be flying out the dipstick tube.
Ford trucks are known to get a milky white slime on the oil fill cap if you only drive it a few minutes at a time.
Are you sure it isn't leaking watered down gas in the engine thru the carb or fuel pump? |
| Back to top |
dhermesc Tractor Guru
Posted: Thu Oct 04, 2012 12:25 pm Post subject: Re: Does it have an oil filter? |
That would be my guess. One oil change should have removed the water. |
| Back to top |
Rick54 Regular
Posted: Thu Oct 04, 2012 1:37 pm Post subject: Re: water in crank case |
sure sounds me like you leaking gas thru carb or fuel pump if equiped. check those ut and you should solve your troubles |
| Back to top |
Tom Arnold Long Time User
Posted: Thu Oct 04, 2012 3:07 pm Post subject: Re: water in crank case |
If that were true, then his fuel consumption should be very high and his oil level would climb higher on the dipstick. The smell of gasoline in the drained oil would be very prevalent also.
Gasoline does not make engine oil turn milky. Water does. Water can be introduced from the exterior due to the dipstick hole being left uncovered or it can come from condensation taking place inside the engine due to the crankcase not breathing properly. I suspect the latter. If the engine breather system is not functioning, then water vapour from the combustion process has no way of exiting the crankcase and it condenses on the internal parts leaving them with a whitish goo that is hard to get rid of. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
