| Author |
Message |
PJH Tractor Expert
Posted: Thu Oct 04, 2012 9:38 am Post subject: Plugged drain - frost free hydrant |
Anybody have any tricks to unstop a plugged weep hole in a frost free yard hydrant? Other than digging it up, that is. . . I have four hydrants out of seven that are plugged and won't drain. All of them are bedded in open graded gravel. I've dug up one, and it won't even drain with nothing around it. It seems to be corrosion - we have lots of minerals in our well water. I actually don't mind digging, but there's a hundred other things that are also calling for attention.
Paul |
| Back to top |
wilamayb Tractor Expert
Joined: 30 Jul 2007 Posts: 2596 Location: Union City, TN
Posted: Thu Oct 04, 2012 9:48 am Post subject: Re: Plugged drain - frost free hydrant |
I dont have any thoughts on repair without digging it up but some folks install the hydrant with a short exension on the drain with a tiny street L on the end, pointed down. This may or may not help. If it is hard water plugging it up I think this may just be a regular occurence for you. |
| Back to top |
Greenday Long Time User
Joined: 08 Jun 2008 Posts: 1402 Location: NW Missouri
Posted: Thu Oct 04, 2012 11:15 am Post subject: Re: Plugged drain - frost free hydrant |
With the hydrant in the off position plumb up a fitting to screw onto the hydrant with a schrader valve so you can put air pressure into it and see if it will clear the drain back |
| Back to top |
Dusty MI Long Time User
Joined: 17 Dec 2000 Posts: 1069 Location: Lansing MI. area
Posted: Thu Oct 04, 2012 3:55 pm Post subject: Re: Plugged drain - frost free hydrant |
| Greenday wrote: | | (quoted from post at 12:15:06 10/04/12) With the hydrant in the off position plumb up a fitting to screw onto the hydrant with a schrader valve so you can put air pressure into it and see if it will clear the drain back |
Maybe after the air some vinegar down the hydrant.
Dusty |
| Back to top |
showcrop Tractor Guru
Posted: Thu Oct 04, 2012 5:31 pm Post subject: Re: Plugged drain - frost free hydrant |
Water doesn't drain quickly through gravel like it does through sand or stone, so some of the water draining out can get higher than the drain then carry fines with it to the drain point. The correct procedure is to use some stone under and around the drain to enable the water to drain quickly down and away. |
| Back to top |
Justin SE IOWA Long Time User
Joined: 21 Sep 2010 Posts: 557 Location: Oskaloosa Iowa
Posted: Thu Oct 04, 2012 5:37 pm Post subject: Re: Plugged drain - frost free hydrant |
I agree 100% with Greenday |
| Back to top |
PJH Tractor Expert
Posted: Thu Oct 04, 2012 7:03 pm Post subject: Re: Plugged drain - frost free hydrant |
I tried 125 PSI yesterday on three of them. No luck. Gonna take one apart tomorrow. I'm wondering if the rubber/leather shutoff can deform and block the drain hole.
Thanks,
Paul |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
