| Author |
Message |
Farmallb Long Time User
Posted: Thu Oct 04, 2012 11:08 am Post subject: Seal for Cub PTO angle shaft. |
I was told on here to get seal # cr11223. This is for the angle housing that fits on the Cub pto and angles it 45* so as to be able to use a flat pulley. The shaft that I need the bearing seal for measures 15/16ths. The Inside of the seal measures 1 1/16. What do you think?? |
| Back to top |
Haas Tractor Guru
Posted: Thu Oct 04, 2012 11:37 am Post subject: Re: Seal for Cub PTO angle shaft. |
I think you are missing the bushing that goes over the shaft. The seal runs on the bushing. |
| Back to top |
Posted: Thu Oct 04, 2012 2:23 pm Post subject: Re: Seal for Cub PTO angle shaft. |
Can you tell me what to ask for to get the bushing? Thanks for the reply. |
| Back to top |
teddy52food Tractor Guru
Posted: Thu Oct 04, 2012 5:17 pm Post subject: Re: Seal for Cub PTO angle shaft. |
When you put the bushing on the shaft, use a sealer or the oil will leak out between the shaft & bushing. |
| Back to top |
gene bender Tractor Guru
Posted: Fri Oct 05, 2012 5:37 am Post subject: Re: Seal for Cub PTO angle shaft. |
If you dont have the flat pulley get the collor that fits over the splines and fastens with a capscrew and large washer to hold it on and that will help the seal your dealer should be able to get the parts you need. |
| Back to top |
Haas Tractor Guru
Posted: Fri Oct 05, 2012 6:12 am Post subject: Re: Seal for Cub PTO angle shaft. |
The bushing goes over the splined shaft and bears against the bearing inner race and acts as a bearing retainer. The bushing is held in place when you install the belt pulley which is held by the bolt in the end of the shaft. If the pulley is not on there, then there is a sleeve that goes over the shaft and held in place with the same bolt that holds the pulley in place. Go to CNGCO.com or call them up and they should be able to get all the parts you need. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
