| Author |
Message |
Walter T New User
Posted: Thu Oct 04, 2012 1:14 pm Post subject: 1939 Farmall H |
Looking for some help our PTO when hooked up will skip out of gear when running I removed the PTO shaft and it looks fine , any Ideas? Thanks |
| Back to top |
Zachary Hoyt Tractor Expert
Posted: Thu Oct 04, 2012 3:03 pm Post subject: Re: 1939 Farmall H |
Is the end of the countershaft in good shape? I have a spare countershaft for an early H if you want one.
Zach |
| Back to top |
w trusz Guest
Posted: Fri Oct 05, 2012 8:46 am Post subject: Re: 1939 Farmall H |
yes it seems to be in good shape the spring is intact how do you know if the spring is good and has enough tension |
| Back to top |
Janicholson Tractor Guru
Joined: 30 Jan 2004 Posts: 18224 Location: St. Cloud, MN
Posted: Fri Oct 05, 2012 7:36 pm Post subject: Re: 1939 Farmall H |
The dogs that slide together to form the ON OFF connection may be deformed enough that pressure causes them to slide apart. An angle grinder and some careful reshaping can make them interlock again. Grind only minimally. Jim |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
