| Author |
Message |
Cal Innes Regular
Posted: Thu Oct 04, 2012 1:34 pm Post subject: JD-350 steering |
I am considering buying a JD-350. The right steering seems to have no ability to turn. The owner had told me it was weak but when we gave it a go there was nothing. Owner says "humph, that's new". He will look at it but says it is most likely just a matter of taking a turn or 2 on the yoke that attaches to the brake lever.... as for me, I am not so sure.
What is involved in repairing that?
Thanks,
Cal |
| Back to top |
LJD Tractor Expert
Posted: Thu Oct 04, 2012 2:22 pm Post subject: Re: JD-350 steering |
Steering problems in crawlers are just about never just "simple adjustments."
With the 350. When you pull back on the steering lever . . . first it decluthes (dis-engages power to the track) and then second . . . it activates a brake as you pull further.
You've got to figure what your problem is. Is there is power to the track all the time - or it is just not braking?
If you run the crawler up a steep incline in 1st gear and then slowly pull back both levers - there should be a point where gravity will let the crawler roll backwards down the hill - even though it's in 1st gear forward and the foot clutch is "up." If it won't roll backwards - it's not declutching. If it DOES roll - then pull back the levers all the way and see if it then stops like you just hit the brakes - because you just DID hit the brakes.
In most cases - there dry-clutch crawlers have stuck or slipping clutch disks AND bad brake bands. On top of that -they often have rusted-stuck linkage.
To test the linkage - hold your foot down hard on the foot-brake pedal and then try to move the right steering clutch lever back and forth. If it won't more without making the brake pedal move with it - it's stuck.
9-10 times from what I've seen - if an owner says "it just needs a simple adjustment" . . . you can bet it needs MUCH more then that. Often $1000s more worth of work unless you do all the repairs yourself and then still - not cheap.
I guess that's one nice thing about Oliver Cletrac and Case 310 and 350 crawlers. No steering clutches at all. Brake bands yes - but they ride in oil and cannot rust. |
| Back to top |
BCnT Tractor Expert
Posted: Thu Oct 04, 2012 8:30 pm Post subject: Re: JD-350 steering |
another thing to check is pull the lid off the steering clutch/brake band housing...look for oil on anything inside...i dropped 5 grand fixing my 350B steering and new chains. |
| Back to top |
CTucker Regular
Posted: Sat Oct 13, 2012 5:10 pm Post subject: Re: JD-350 steering |
I have an Oliver OC46 that won't drive on the right side. It has a bad clutch. Yes it has clutches on each side. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
