| Author |
Message |
gene watkins Regular
Posted: Thu Oct 04, 2012 3:10 pm Post subject: 800 caseomatic eagle hitch |
59 caseomatic eagle hitch. how do i ck oil in rockshaft and or add oil? there is no petcock on the block,but there is an allen plug under manifold will that drain block? thanks for all the help. |
| Back to top |
Adirondack case guy Tractor Guru
Posted: Thu Oct 04, 2012 4:09 pm Post subject: Re: 800 caseomatic eagle hitch |
I have been around Case tractors since childhood. I might be a bit dense sometimes, but I have no idea what you are refering to. The 800 has a external 3pt lift cylinder and no rockshaft housing, just a cast block that supports the 3pt rockshaft that has greese jerks that lube it. You got pics. of what you are refering to?
Loren |
| Back to top |
Gene Dotson Tractor Expert
Joined: 03 Dec 2001 Posts: 1703 Location: Ohio, De Graff
Posted: Thu Oct 04, 2012 4:23 pm Post subject: Re: 800 caseomatic eagle hitch |
Hydraulic oil level is checked on lower right side of the hydraulic housing. It is a 1/8 inch pipe plug. Engine coolant is drained through a 1/4 inch pipe plug in the bottom of the oil filter housing.
Gene |
| Back to top |
Posted: Thu Oct 04, 2012 4:57 pm Post subject: Re: 800 caseomatic eagle hitch |
i am sorry if i stated rockshaft wrong. on the last page of the c 201 case shop manual fig c718 it says install 1 pint of sae 90 transmission oil in the rockshaft housing. i could not find grease fittings or a plug. sorry about the screw up . |
| Back to top |
INCase Long Time User
Posted: Fri Oct 05, 2012 8:11 am Post subject: Re: 800 caseomatic eagle hitch |
there is a petcock on the side of the oil filter mounting plate/assembly that will drain the block. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
