5030
peter82
PostPosted: Thu Oct 04, 2012 4:26 pm    Post subject: 5030 Reply to specific post Reply with quote
hi the clutch is getting weak in my 5030 i have a new clutch what should i expect to pay to get someone to put it in it has a loader and is 4wd just dont want to get ripped off thanks
RodinNS
PostPosted: Thu Oct 04, 2012 8:14 pm    Post subject: Re: 5030 Reply to specific post Reply with quote
A lot. Even more if it has a cab... unless you find someone to bid the job without ever having changed one of those before...
Bank on a day's labor plus whatever incidentals you run into. More often than not the PTO drive spline on the pressure plate are bad along with the PTO input shaft on the transmission. Normally you also change the engine rear seal and seal carrier gasket along with the core plugs in the rear of the engine while you're in there.
Ford 30 series tractors are just a bugger to split. The fuel tank and steering pedestal need to come out for best access to the housing top bolts... and that can take a bit of time, plus working around the loader frame.
Rod
