Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Fuel Transfer Pump Problem
Post new topic    Yesterday's Tractors Forum Index -> Tool Talk
Aug
PostPosted: Thu Oct 04, 2012 5:38 pm    Post subject: Fuel Transfer Pump Problem Reply to specific post Reply with quote
I have a Tuthill/Fillrite knockoff fuel transfer pump I bought new a month ago. Have only ran maybe 150 gal of diesel through it and now you have to loosen the filter from housing to make it prime. Not a big deal but is really a pain and makes a mess. This thing is SUPPOSED to be new. Any help would be greatly appreciated.
retired farmer
PostPosted: Thu Oct 04, 2012 6:21 pm    Post subject: Re: Fuel Transfer Pump Problem Reply to specific post Reply with quote
Take it back where you got it. Should have a warranty doesn't it?
Aug
PostPosted: Thu Oct 04, 2012 7:31 pm    Post subject: Re: Fuel Transfer Pump Problem Reply to specific post Reply with quote
Unfortunately I made the mistake of buying it at a whole sale type tool store while on vacation. I paid $199+tax for pump, hose, and auto nozzle which I thought was a good deal at the time...
Jon Hagen
PostPosted: Thu Oct 04, 2012 7:49 pm    Post subject: Re: Fuel Transfer Pump Problem Reply to specific post Reply with quote
Pull it off the takn and check that the dip tube has an air tight seal to the pump. An air leak in that tube will make it lose it's prime.
JDseller
PostPosted: Thu Oct 04, 2012 11:57 pm    Post subject: Re: Fuel Transfer Pump Problem Reply to specific post Reply with quote
You are finding out why it was half the price of a true Fillrite pump. My brother just loves the great "deals" at HF and Northern Tool. Whenever he does anything it takes twice as long because he is using JUNK. He has two of those Fillrite knock offs. Neither of them work right either. On the one you can hold the hose down by the ground and it will usually prime.
jon f mn
PostPosted: Fri Oct 05, 2012 2:26 am    Post subject: Re: Fuel Transfer Pump Problem Reply to specific post Reply with quote
AH!! the old "thought it was a good deal at the time" gag. LOL I've fallen for that one myself.
View user's profile AIM Address
Dalet
PostPosted: Fri Oct 05, 2012 5:15 am    Post subject: Re: Fuel Transfer Pump Problem Reply to specific post Reply with quote
Why is the filter on the suction side of the pump? My fillrite is on the outlet of the pump, no problem priming when its that way.
Aug
PostPosted: Fri Oct 05, 2012 7:32 am    Post subject: Re: Fuel Transfer Pump Problem Reply to specific post Reply with quote
The filter is on the outlet side. When you start
it nothing comes out but as soon as you loosen the
filter from the housing it will start pumping
immediately. I'm assuming doing this removes the
air??
Dalet
PostPosted: Fri Oct 05, 2012 10:00 am    Post subject: Re: Fuel Transfer Pump Problem Reply to specific post Reply with quote
Aug wrote:
(quoted from post at 10:32:22 10/05/12) The filter is on the outlet side. When you start
air??
I'm not sure why it does that, have you tried a new filter?
Aug
PostPosted: Fri Oct 05, 2012 12:20 pm    Post subject: Re: Fuel Transfer Pump Problem Reply to specific post Reply with quote
Filter is brand new
retired farmer
PostPosted: Fri Oct 05, 2012 6:01 pm    Post subject: Re: Fuel Transfer Pump Problem Reply to specific post Reply with quote
If you still have the paperwork that came with the pump, isn't there a phone number in it for service? Call it and tell them what it is doing.
Dave in Tx
PostPosted: Fri Oct 05, 2012 7:10 pm    Post subject: Re: Fuel Transfer Pump Problem Reply to specific post Reply with quote
As Jon said, tighten the suction pipe. Just went thru this yesterday after putting new gears and all in it. Had to loosen the filter to get it to prime. Resealed the suction pipe and works like a new one.
El Toro
PostPosted: Sat Oct 06, 2012 1:48 pm    Post subject: Re: Fuel Transfer Pump Problem Reply to specific post Reply with quote
We removed a transfer pump from an old B29 airplane at work and you didn't need to prime it. I was 24 volt, but it would work off 12 volts. I used it to pump out my fuel oil tank when I painted it after it was sandblasted. I think it had 1-1/4 pipe threads. We used 3/4 hose along with 3/4 to 1-1/4 pipe bushings. Still would pump a lot of fuel quickly. That plane had nice pressure gauges on it. I still have one. Hal
