Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
1070 PTO don't shut off
Post new topic    Yesterday's Tractors Forum Index -> Case and David Brown
Kow Farmer
PostPosted: Thu Oct 04, 2012 6:59 pm    Post subject: 1070 PTO don't shut off Reply to specific post Reply with quote
Hi everyone,
Well I got to use my 1070 tonight (Thursday) to haul manure. As I was letting the tractor warm up, I noticed the PTO shaft was turning. I tried to disengage the lever a couple of times, but no luck. Does the PTO turning all the time while the engine is running going to hurt it? I don't use the PTO a lot, but more in Winter with a snowblower. Is there something I can do to fix this easily? I don't have a shop manual yet. I have a neighbor across the field from me that is a Case mechanic too. Thanks everyone.
Kow Farmer
RGMartin
PostPosted: Fri Oct 05, 2012 3:09 am    Post subject: Re: 1070 PTO don't shut off Reply to specific post Reply with quote
Is it running full power/speed, or just kinda loafing along at 1/4 speed with very little torque behind it?
If at full power could be as simple as a broken cable.
We have a 7 and 870 that just kinda idle at a very low speed when not engaged. Something like a small square baler it will turn at a very reduced rate, a feed grinder or spreader that requires more torque don't turn until you engage it. Both have been this way as long as I remember. While they may not be "right", 30 years doesn't seem to have hurt them.
Kow Farmer
PostPosted: Fri Oct 05, 2012 3:48 am    Post subject: Re: 1070 PTO don't shut off Reply to specific post Reply with quote
Hi RG,
The PTO is running at full speed without any implement hooked on, I mean it doesn't slow down or speed up. I did notice if I had the manure really loaded that the PTO will not turn then. My biggest fear is when I put my double augered snowblower on for the Winter. Kind of dangerous with the PTO constantly on. Thanks for responding.
Kow Farmer
Agri King
PostPosted: Fri Oct 05, 2012 4:20 am    Post subject: Re: 1070 PTO don't shut off Reply to specific post Reply with quote
Kurt, If the cable is good you are going to need to pull the pto out. I have seen when guys let the pto run all the time like this the friction plates will cut into the drum over time. There are a number of things to look at when you have the pto out, Kurt give me a call.
casecollectorsc
PostPosted: Fri Oct 05, 2012 6:05 am    Post subject: Re: 1070 PTO don't shut off Reply to specific post Reply with quote
Check the adjustment of the cable. Might not be moving the spool far enough. Don't have the book here to check what it says.
Kow Farmer
PostPosted: Fri Oct 05, 2012 6:33 am    Post subject: Re: 1070 PTO don't shut off Reply to specific post Reply with quote
Thanks for the info. I will have to call you when I get some more time. Maybe you can walk me through it? I appreciate the help.
Kow Farmer
Case Nutty 1660
PostPosted: Fri Oct 05, 2012 8:48 am    Post subject: Re: 1070 PTO don't shut off Reply to specific post Reply with quote
my guess is with Agri King also if you need/want the service manual scaned for the steps let me know cnt
Kow Farmer
PostPosted: Fri Oct 05, 2012 9:09 am    Post subject: Re: 1070 PTO don't shut off Reply to specific post Reply with quote
Case Nutty,
Could you please scan those for me? That would be very much apprecited sir! Thank you very much.
Kow Farmer
Case Nutty 1660
PostPosted: Fri Oct 05, 2012 10:37 am    Post subject: Re: 1070 PTO don't shut off Reply to specific post Reply with quote
will do send me a e-mail stan2670@collinscom.net and I will send as attachments so you can print them if you like cnt
grandpajohn
PostPosted: Fri Oct 05, 2012 5:55 pm    Post subject: Re: 1070 PTO don't shut off Reply to specific post Reply with quote
I already have the manual scanned and available on my wedsite. Just go the the user manual section and then to case you will see many manuals including the parts manual for the 1070 and the entire service manual.
gramps
service manual
Kow Farmer
PostPosted: Fri Oct 05, 2012 6:31 pm    Post subject: Re: 1070 PTO don't shut off Reply to specific post Reply with quote
Thank you for the great info! I appreciate it very much.
Kow Farmer
(Kurt)
