| Author |
Message |
Dennis Solsbery Guest
Posted: Fri Oct 05, 2012 2:44 am Post subject: Power Steering Reservoir |
Anybody know where I can get the reservoir assy. for a Ford 800? I have one, but all the guts are missing. |
| Back to top |
showcrop Tractor Guru
Posted: Fri Oct 05, 2012 4:29 am Post subject: Re: Power Steering Reservoir |
Does that mean that you have the pump and reservoir but you need just the nut, plate and filter that goes inside? or do you need the whole pump assy? There are two pumps on ebay now. |
| Back to top |
awhtx Tractor Guru
Joined: 16 Jan 2002 Posts: 5048 Location: Lampasas, TX
Posted: Fri Oct 05, 2012 5:31 am Post subject: Re: Power Steering Reservoir |
There were two different pumps used by Ford. One is called the sleeve pump and the guts of the pump fit inside the reservoir canister. The other pump has the reservoir mounted on top of the pump. |
| Back to top |
Posted: Fri Oct 05, 2012 11:21 am Post subject: Re: Power Steering Reservoir |
Actually, all I need for now is just the stuff that goes inside the reservoir. If that doesn't help, then I'll go for the entire pump. |
| Back to top |
Larry NCKS Tractor Guru
Joined: 23 Dec 2001 Posts: 3711 Location: Washington, KS/Lincoln, NE
Posted: Fri Oct 05, 2012 2:59 pm Post subject: Re: Power Steering Reservoir |
Not that I have or know where any of this stuff is, but you ought to tell us which pump you have. Look at the previous reply that sescribes the two options. |
| Back to top |
Kurt-NEPA Long Time User
Joined: 05 Mar 2009 Posts: 737 Location: Tunkhannock, PA
Posted: Fri Oct 05, 2012 3:31 pm Post subject: Re: Power Steering Reservoir |
Does you pump look like this Eaton pump?
or this Ford Piston Pump
| Back to top |
Posted: Fri Oct 05, 2012 4:14 pm Post subject: Re: Power Steering Reservoir |
I have the Eaton pump. |
| Back to top |
dsolsbery New User
Posted: Fri Oct 05, 2012 4:44 pm Post subject: Re: Power Steering Reservoir |
This is what I need.
| Back to top |
Posted: Sat Oct 06, 2012 2:24 am Post subject: Re: Power Steering Reservoir |
Messicks shows the retainer assembly and filter element, so they are available new from CNH. They say to call on the other parts, which probably means they are no longer available, but might be worth a call. They often have some used parts, and great access to warehouses nationwide. |
| Back to top |
| Back to top |
Posted: Sat Oct 06, 2012 2:41 am Post subject: Re: Power Steering Reservoir |
Another possibility is Strangers. They rebuild Eaton pumps and have some used parts available. It might be worth contacting them. Reasonable prices on rebuilding the pump also.
http://www.stangerssite.com/EPrebuilding.html |
| Back to top |
Posted: Sat Oct 06, 2012 12:11 pm Post subject: Re: Power Steering Reservoir |
Kurt, thanks for the link. I'm in touch with them now. |
| Back to top |
Posted: Sat Oct 06, 2012 12:12 pm Post subject: Re: Power Steering Reservoir |
Thanks again, I put a bid in. |
| Back to top |
Posted: Sun Oct 07, 2012 4:52 am Post subject: Re: Power Steering Reservoir |
I looked at Messicks, and all I found was the pump with the reservoir mounted on the back. |
| Back to top |
Posted: Sun Oct 07, 2012 5:07 am Post subject: Re: Power Steering Reservoir |
Follow this link
http://www.messicks.com/NH/8454.aspx
Then click
Front Axle and Steering
Then click
03C03 Power Steering Pump, Oil Res......
That should get you there. I searched for a 661, but its the same pump used on a 8X1 and 6X1 Tractors |
| Back to top |
