| Author |
Message |
jCarroll Long Time User
Posted: Fri Oct 05, 2012 3:49 am Post subject: Grounding a metal building ? |
I'm having a metal skin shed built (post and beam with metal siding
and roof). Will eventually have electric service.
Should the building be grounded? How do lightning rods fit into
this issue? |
| Back to top |
David G Tractor Guru
Posted: Fri Oct 05, 2012 4:41 am Post subject: Re: Grounding a metal building ? |
I am not aware of any regulation regarding this. It will be interesting to hear other responses. Any electrical outlet or device should be grounded. |
| Back to top |
buickanddeere Tractor Guru
Joined: 31 May 2003 Posts: 23624 Location: in front of computer
Posted: Fri Oct 05, 2012 5:29 am Post subject: Re: Grounding a metal building ? |
Yes, no and maybe. If the door frames are metal, it's not unusual to see those grounded.
If there is any livestock in the future. Then the water system and metal stalls should all be bonded together.
Running four wires to the shed panel instead of a three wire will prevent a lot of problems with tingle voltage.
This would be the time to deep bury a couple of ground plates 10 ft deep and 8 ft each side of the shed panel. Run #6 copper up for the connection. |
| Back to top |
Ted in NE-OH Guest
Posted: Fri Oct 05, 2012 6:53 am Post subject: Re: Grounding a metal building ? |
Lightning rods depends on how frequently you get lightning storms. |
| Back to top |
Bill46 Guest
Posted: Fri Oct 05, 2012 7:18 am Post subject: Re: Grounding a metal building ? |
For a single circuit bldg, if the sysyem is grounded...you need not have one. If you have more than 1 circuit, you must have at least 10ft of metal waterline in the ground to attatch to or an 8ft ground rod. The ground rod wire must be at least as as large as the feeder wires to the bldg. |
| Back to top |
Posted: Fri Oct 05, 2012 11:37 am Post subject: Re: Grounding a metal building ? |
What code book are you looking at ? |
| Back to top |
John T Tractor Guru
Posted: Fri Oct 05, 2012 1:32 pm Post subject: Re: Grounding a metal building ? |
Its been yearssssssss since I was an electrical design engineer, but way back when there wasnt any requirement the outer metal skin of a pole barn shop etc be grounded, but it wouldnt hurt if you wished to do so. Problem is theres half A$$ "grounding" like if you bonded to one sheet of metal and relied on all the screws n nails for an effective current path among all the panels orrrrrrrrrrr run a braided copper wire around the building and bond to each n every piece which I doubt youre interested in doing....
ITS THE ELECTRICAL SERVICE THAT REQUIRES PROPER GROUNDING instead of the metal skin sheets.
Sure you can install lightning rod protection if you wish but again its not a requirement Im aware of and Id worry less about the metal shop then a frame home as far as fire is concerned.
John T |
| Back to top |
Bill46 Guest
Posted: Mon Oct 08, 2012 3:27 am Post subject: Re: Grounding a metal building ? |
Went to the shop and looked it up in the new code.
They changed the rules. If it is a new building, you must have a piece of re-bar in the concrete grounded to the box and the building also. Then, the boulding and the box must be grounded to the ground rod.
NEC 250.52. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
