| Author |
Message |
Mark McNally Guest
Posted: Fri Oct 05, 2012 4:10 am Post subject: International TD 340 steering |
I'm looking at a low hour TD 340 (860 hours) that the left side steering clutch doesn't release. What could be my best or worse case scenarios. The dozer has been used on light farm work it's whole life, and has been sitting for several years.
Thanks in advance for your input and suggestions.
Mark |
| Back to top |
Charlie Tractor Expert
Posted: Fri Oct 05, 2012 6:15 am Post subject: Re: International TD 340 steering |
Are you sure it's the steering clutch and not the pivot brake? When you pull back on the lever on either side, the clutch disengages on that side and then when you pull it further, the pivot brake engages for an even sharper turn. If the brake is just stuck, you might try engaging both brakes with the pedal with both levers forward (engaged)and it might break loose. If it is the steering clutch, it might have been overadjsuted, but I think that's unlikely. |
| Back to top |
mmi New User
Posted: Mon Oct 08, 2012 4:24 am Post subject: Re: International TD 340 steering |
These are different from standard systems
wet drive / dry stop
would suspect meter wrong
there is an adjustment by your feet to reduce free travel
otherwise it needs torn down and at least dry brakes replaced.
in a shed tracks and finals removed
Where is it located? |
| Back to top |
dej(Jed) Tractor Expert
Posted: Tue Oct 09, 2012 9:18 am Post subject: Re: International TD 340 steering |
Mark-any way you do it is going to be a pricey labor related fix. |
| Back to top |
PD Mechanical Regular
Joined: 05 Aug 2004 Posts: 220 Location: Syracuse, NY
Posted: Fri Oct 19, 2012 5:00 am Post subject: Re: International TD 340 steering |
Mark. The 340 does not have steering clutches. It uses a planetary steering system similar to the TD7 and 8. It's rather complicated to describe but basically consists of two steel discs and two sets of shoes on each side. One disc is held stationary to drive the corresponding side and then released to make a turn and the other disc is stopped to make a spot turn. In other words no fiber/steel clutch pack with pressure plate and brake drum. The linings on the shoes are probably worn out. They can be relined but may have damaged the discs if allowed to run metal on metal. Good luck. Steve. www.pdmechanical.com |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
