| Author |
Message |
oldtanker Tractor Guru
Posted: Fri Oct 05, 2012 8:46 am Post subject: If you could....... |
If you could make any changes to a Farmall M to make it more usable today what would they be? Think like money was a consideration.
I'm not going to commnet as I think most of you guys know what I think is wrong with the M for todays needs.
Rick |
| Back to top |
F-Dean Long Time User
Posted: Fri Oct 05, 2012 8:56 am Post subject: Re: If you could....... |
Live hydraulics, power steering & 3-point -- all standard |
| Back to top |
wisbaker Tractor Expert
Posted: Fri Oct 05, 2012 9:01 am Post subject: Re: If you could....... |
Live/independent PTO, live hydraulics, 3 point,
power steering and differential lock. |
| Back to top |
BigTone Regular
Posted: Fri Oct 05, 2012 9:05 am Post subject: Re: If you could....... |
Power steering, live hydraulics and a 3 pt. hitch would make life MUCH easier for me. |
| Back to top |
MisterT Long Time User
Posted: Fri Oct 05, 2012 9:26 am Post subject: Re: If you could....... |
IH realized the shortcomings of the Farmall M, so they introduced the 400 and then the 450. |
| Back to top |
Posted: Fri Oct 05, 2012 9:38 am Post subject: Re: If you could....... |
| MisterT wrote: | (quoted from post at 10:26:21 10/05/12)
LOL I know that. I'm going to be farming fulltime in the spring. I have a 1206 (used year round), the M which isn't or hasn't been used much and a couple of Ford 8N's that get used a lot in the on seasons but not in the winter. I just picked up an IH 85 Grinder Mixer and can run that and the poo spreader with the M and am thinking that up grading the M would make it more suited for what I need. Replacing it right now just isn't in the budget. So I'm fishing for ideas. I need a field cultivator and a combine much more than I need to trade/sell a traactor for an up grade.
Rick |
| Back to top |
BigTone Regular
Posted: Fri Oct 05, 2012 9:50 am Post subject: Re: If you could....... |
Just thought of something, could you imagine how much more useful the M would be with 4 wheel drive!! |
| Back to top |
Andrew Z Tractor Expert
Posted: Fri Oct 05, 2012 10:02 am Post subject: Re: If you could....... |
lower first and reverse gears standard.
Funny thing is that what everyone is saying was
around as either factory/ aftermarket or could be
taken from a latter series, ie the 400/450.
Andrew |
| Back to top |
flambeauone Regular
Posted: Fri Oct 05, 2012 12:47 pm Post subject: Re: If you could....... |
Add power steering, saginaw three point, and live hydraulics.
Maybe a 560 wide front or a shwartz with some float tires on
front would also be nice. A nice seat with a backrest is also
high on my list. As others have said dif lock, lower gears and
gour wheel drive would be awesome but not very practical
on a budget. |
| Back to top |
notjustair Long Time User
Posted: Fri Oct 05, 2012 3:14 pm Post subject: Re: If you could....... |
Live hydraulics. I'd be fine with the five gears if it had a high
and low range like our 856 and 966 had. I love the narrow
front, but I would love to have a little different design so every
other tractor you look at didn't wobble like a drunkard.
Did I mention hydraulics? |
| Back to top |
SadFarmall Long Time User
Joined: 17 Jan 2011 Posts: 659 Location: Bullengarook, Victoria, Australia
Posted: Fri Oct 05, 2012 4:10 pm Post subject: Re: If you could....... |
Well, for me it would be a differential lock. That would make ploughing easier on occasion. Also an instrument lamp for the ammeter, so it could be seen at night. It's a small thing, but I don't like having instruments, which cannot be seen all the time.
IHC made some improvements to the M out here, which included three point linkage with the hydraulic cylinder INSIDE the gearbox lid and altering the swinging drawbar to strengthen it and make height adjustment easier.
1st gear on many Farmall M tractors here was a low speed gear as standard. By the time the AW-7 Diesel was made, a low low first gear was the norm.
Basically other than the differential lock and ammeter lamp, I wouldn't change much. I just work the tractor with old IHC and Sunshine equipment and it performs admirably all the time.
SadFarmall |
| Back to top |
DeltaRed Tractor Guru
Joined: 25 Feb 2010 Posts: 6416 Location: Delta,colorado
Posted: Fri Oct 05, 2012 5:01 pm Post subject: Re: If you could....... |
My old SM is JUST FINE the way it is.It has live
hydralics and a 3 point.M/W live pto.Power steering
would be nice(some times).If an M had all those
'modern' improvements,It just would'nt be an M!BTW,I
just spent several hours 'seat time' on my "Super" today.
| Back to top |
Janicholson Tractor Guru
Joined: 30 Jan 2004 Posts: 18229 Location: St. Cloud, MN
Posted: Fri Oct 05, 2012 7:29 pm Post subject: Re: If you could....... |
Durable paint. Better seat bushings (urethane)
Better starter drive. Two stage clutch for PTO/s.
All fixed on the 400 (except better paint). Jim |
| Back to top |
Old Iron Regular
Joined: 31 Aug 2007 Posts: 240 Location: Northwest Kansas
Posted: Fri Oct 05, 2012 9:31 pm Post subject: Re: If you could....... |
My '49 M has Char Lynn power assist steering w/wide front end, live hydraulics with a DuAl loader, and a Saginaw 3pt.
Plus a set of tire chains for snow pushing.
Live PTO would be nice,... but the old M is a handy son-of-a-gun just the way I have it set up now. |
| Back to top |
scotc Tractor Expert
Posted: Sat Oct 06, 2012 2:04 pm Post subject: Re: If you could....... |
Just the spreader and feed grinder? Sounds just about right. |
| Back to top |
