having problems bleeding inter 784
grahame barritt
PostPosted: Fri Oct 05, 2012 11:42 am    Post subject: having problems bleeding inter 784 Reply to specific post Reply with quote
hi have replaced some fuel pipes and filter but having problems geting it started cant find a bleed screw on the injection pump it has had a electric pump fitted can any one offer any help please thank you kind regards grahame
JimB2
PostPosted: Fri Oct 05, 2012 1:51 pm    Post subject: Re: having problems bleeding inter 784 Reply to specific post Reply with quote
Hi, only bleed screws on top of filters. If you have an electric fuel pump attached should be easy to bleed the air out of the filters. Then put the Stop/Start/Run level in Start position, throttle about 3/4 open and crank engine with starter for no more than 30 seconds at a time, then let starter cool off, try this a couple time, if no go then loosen a couple injector lines at the rear of the injection pump and try cranking engine again.
Hope this helps
JimB
