Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
highest compression for propane
Goto page 1, 2  Next
Post new topic    Yesterday's Tractors Forum Index -> Tractor Pulling
1948 mm
PostPosted: Fri Oct 05, 2012 4:50 pm    Post subject: highest compression for propane Reply to specific post Reply with quote
I am building a 403 propane engine and wondering how high can I get the compression using stock parts. I have a G gas with 4.75" pistons 10a4210 heads and I am running around 11.3/1 compression with no detonation on pump gas. It does diesel when shutting down hot. I was wondering how high you could go with LP? Thanks
unstylish
PostPosted: Fri Oct 05, 2012 5:06 pm    Post subject: Re: highest compression for propane Reply to specific post Reply with quote
11 to 1? No detonation on pump gas? I bet it does, or it sure does not have much timing. I wouldnt go more than 11 to 1 on LP.
Dblair
PostPosted: Fri Oct 05, 2012 5:59 pm    Post subject: Re: highest compression for propane Reply to specific post Reply with quote
won't take to much to melt those pistons down you better get some octane .
buickanddeere
PostPosted: Sat Oct 06, 2012 9:24 am    Post subject: not about compression ratio, it's compression pressure/heat Reply to specific post Reply with quote
There is a huge lack of understanding here that nobody seems to be learning . No matter how many times it's explained here and elsewhere.0
Compression pressure is controlled every bit as much by the cam as it is by compression ratio.
Take a look at how a reciprocating engine works. High compression robs power from the engine. High expansion ratio adds power.
Detonation is caused when the air fuel mixture is heated from compression. Rising above the ignition temp of the fuel.
So keep he air fuel mix cooler or raise the fuel's ignition temp.
Depending on timing, cam, compression and combustion chamber design. Something between 8 and 16 to 1 depending........
MLPANKEY
PostPosted: Sun Oct 07, 2012 3:45 pm    Post subject: Re: not about compression ratio, it's compression pressur... Reply to specific post Reply with quote
yeap just stick a cam in with alot of duration on a long rod engine that doesnt dwell long at bdc and when the valves close after pistons traveled a 1/4 ways up the bore can run alot lower octane than one that has valve closed before piston moves up the bore . piston speed its simply the best way to move air .
mm585
PostPosted: Sun Oct 07, 2012 5:42 pm    Post subject: Re: highest compression for propane Reply to specific post Reply with quote
compresion = horsepower! M&W, heiseler, and the rest of the lot made pistons with a dome to make power. Ask any engine builder thats the way it is. Im not saying a good camshaft doesnt assist in the combo but compresion is the place to start my my book. I know for a fact a 900 inch moline at eleven to one with 345 pounds of cyl. press. runs very well on LP.
MMMMMMMMM
PostPosted: Sun Oct 07, 2012 7:52 pm    Post subject: Re: highest compression for propane Reply to specific post Reply with quote
345 psi is more than a MM diesel has. Try running your MM diesel only on LP and then tell me how well it runs.
buickanddeere
PostPosted: Mon Oct 08, 2012 1:50 pm    Post subject: Re: highest compression for propane Reply to specific post Reply with quote
Tell me if it takes more power to push a piston to TDC with 11 to 1 compression that it does on an otherwise identical 8 to 1 engine?
Tell me how many more times the gasses can expand on the power stroke of an 11 to 1 engine vs an 8 to 1 engine.
MLPANKEY
PostPosted: Mon Oct 08, 2012 4:05 pm    Post subject: Re: highest compression for propane Reply to specific post Reply with quote
unleas we are talking about two cylinder jd. Compression increases will always increase torque.The piszton gets drove to tdc by the same combustionmn force driving another piston from tdc to bdc
VicS
PostPosted: Mon Oct 08, 2012 5:20 pm    Post subject: Re: not about compression ratio, it's compression pressur... Reply to specific post Reply with quote
What about a little eco-boost Ford? They inject gasoline at 2200 psi. Just like a diesel does. Someone is probably working on putting that fuel injection on a old tractor now. Supposedly good for 20% more hp
buickanddeere
PostPosted: Mon Oct 08, 2012 7:01 pm    Post subject: Re: highest compression for propane Reply to specific post Reply with quote
Ever heard of a reciprocating engine making power
on the compression stroke?
Power is what happens on the power/expansion
stroke.
" Power" is the mean average pressure exerted on
the piston top during the power stroke.
Expansion ratio is just as important as peak
pressure at TDC.
There are diminishing returns when increasing
compression, up to no power advantages.
LarryM
PostPosted: Mon Oct 08, 2012 7:42 pm    Post subject: Re: not about compression ratio, it's compression pressur... Reply to specific post Reply with quote
What may seem easy to some may seem particularly hard for other people. For example explaing to people that with my phone I can log into work and see everything from the fire alarms to lighting to temperature control and have the ability to operate many things is to them mind boggling. To me it is quite simple. You have people of all skill sets on this site. Some people on this site have a hard time wiring up an alternator. Some of us still have equations from physics class 20 years ago floating in our head. For example the acceleration due to gravity. Why that is still in there I do not know. Maybe it is because we tested it with an empty half barrel off an 80 foot tower. What I have learned is to accept that people come with varying skill sets and varying talents. As smart as you are I am amazed that you cannot see that.
MLPANKEY
PostPosted: Tue Oct 09, 2012 4:06 am    Post subject: Re: highest compression for propane Reply to specific post Reply with quote
buickanddeere wrote:
(quoted from post at 20:01:06 10/08/12) Ever heard of a reciprocating engine making power
stroke.
pressure at TDC.
The piston being drove down on the power stroke is driving a piston up on the compression stroke. The gains on compression do get porpitionally smaller as compression goes up for instance 8.1 changed to 12.1 will show a higher gain than 12.1 to 16.1 but theres still a gain in power. When the power gain gets so proportionaly low its basically non existant there still gains in overall torque. The old science for every action theres equall or greater reaction.
Dodgeit
PostPosted: Mon Oct 15, 2012 11:32 am    Post subject: Re: highest compression for propane Reply to specific post Reply with quote
I'll throw this in just for Shitzengiggles. Two indentical make and model engines. Both at 11-1 compression. The only difference between the two is dome height on the piston. One is flat topped and the other has a 20cc dome. Running 91 octane pump gas.
All build componets to include, setting, temprature, humidity, and anything else you can think of is the same for both engines.
Which engine will be able to run more advance without detonation, in a high load situation?
B&D, MLpankey, please refrain from ruining the fun for others. I know you know the answer. I want to see how many others do.
Hint the answer is the same for any fuel type.
Dodgeit
PostPosted: Wed Oct 17, 2012 6:42 am    Post subject: Re: highest compression for propane Reply to specific post Reply with quote
Dodgeit wrote:
(quoted from post at 14:32:03 10/15/12) I'll throw this in just for Shitzengiggles. Two indentical make and model engines. Both at 11-1 compression. The only difference between the two is dome height on the piston. One is flat topped and the other has a 20cc dome. Running 91 octane pump gas.
Since no one ventured a reply. I have to wonder, if the question was too hard?
B&D, MLpankey you two are free to post the answer, as is anybody else.
Post new topic    Yesterday's Tractors Forum Index -> Tractor Pulling All times are GMT - 8 Hours
Goto page 1, 2  Next
Page 1 of 2
